Results 1 to 14 of 14
Thread: Water leak but, from where???
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Hi all, 1995 525i 5 spd
    During the past two weeks I took my car to the car wash twice and no water leaks. Today it snowed a little but the snow melted quickly. Now I have water leaks on the front pillars! Anyone know where the water would be coming from?
    Below is a link of the water leak on the pillar
    Thanks in advance!
    http://i1378.photobucket.com/albums/...psn1vhv7ln.jpg
    Dec 2004
    CT, USA
    e28, e34, e39
    If it's not the sunroof drain tubes leaking then maybe a bad windshield seal?
    demet
    Virginia
    95 525, 93 M5, 05 X5 x2
    Is the floor wet?
    My guess is sunroof drain.
    First step would be to make sure the drain tube is clear. I use a three foot piece of 3/8" outside diameter plastic tubing. Get the stiff kind, not the clear, soft type.
    Clear both sides. Check for leaks using a garden hose to let water run across the front side of the sunroof for 10 minutes.
    If still leaking, it may be the drain tube connection to the sunroof cassette.
    You'll have to drop the headliner a bit to check the attachment of the drain tube to the sunroof cassette. These connections don't typically fail like they do in newer model BMWs.
    Could also be a crack in the tube, again an unlikely occurrence.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    The floor is bone dry. I don't understand why it's leaking now. I washed the car a couple times and had a couple of snow storms and never leaked. Is there a DIY that will show me how to access the drain tubes for the sun roof?
    Thanks!
    Virginia
    Here is a photograph of the driver's side drain. It exits through the forward jack point on the same side. If you carefully pour water through the drain, you should see it dripping below though the jack point. If it does not drain then you have a clog, so use the tubing mentioned above to unclog it. If it drains but nothing or very little exits though the jack point then it's found another path...your A column, and you will have to remove the A column cover and drop the headliner shell enough to have a look at the tube attachment point.. In the attached photograph, the drain hole is the small, round opening in the lower left corner. The narrow, vertical, black piece is the air deflector that pops up when the sunroof is retracted. The wide, black piece is the sunroof track. Hope this helps.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I cannot see the image.
    Virginia
    I will try to reattach. For some reason, the image does not show when using mobile devices to access the forum.
    NW suburban Chicago
    hiss by my window
    Looks like a sunroof drain to me also.
    I've heard of them simply falling off the nipples(one on each corner) on the sunroof cassette.
    See if you can get a look at that corner by removing the a-pillar cover, sun visor and grab handle, then pulling the headliner down a bit
    Jan 2016
    Ca
    2001 525it
    Sunroof drains or bad hose
    Virginia
    Hoping this works. If not, would someone please tell me how to post images directly?
    Attachment 596286
    Quote Originally Posted by GregT53 View Post
    Attachment 596286
    Sorry, just can't figure this out. It's a nice image, too!
    NH, USA
    1995 E34 540i/6
    Don't upload the image onto the forum tool. Use an external image host of your choosing such as photobucket, imgur, imageshack, etc and upload it there then copy the direct url in between the tags ['quickimg]<url here>['/quickimg] (remove quotes). This way, people can also view the image publicly w/o logging in to the forum which is a pain.
    Virginia
    @anonoh: Thanks for the instructions and for posting the image. By now, the OP probably has everything fixed!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    What is that picture? It's hard to see what it is.
    I'm trying to figure out how to remove the A pillar. The rubber trim won't budge. I believe the A pillar pops right out but the rubber trim is in the way.
    Virginia
    I explained the picture in a post above.
    Pull the rubber trim off to remove the A pillar.
  1. Leak, but can't find where its coming from?
    By csap in forum 1991 - 1999 (E36)
    Last Post: 02-05-2012, 04:13 PM
  2. Coolant, but from where?
    By pioneerniles in forum 1991 - 1999 (E36)
    Last Post: 02-09-2009, 08:44 PM
  3. Water leak in car where is it coming from?
    By jwf1999 in forum 1991 - 1999 (E36)
    Last Post: 02-12-2007, 03:32 AM
  4. Antifreeze leak but cant tell where from?
    By BIMMERBOYZ in forum 1983 - 1991 (E30)
    Last Post: 06-26-2005, 12:01 PM
  5. Where is oil leaking coming from??? (PIC)
    By dave162 in forum 1991 - 1999 (E36)
    Last Post: 10-31-2004, 01:34 AM
