Results 1 to 4 of 4
Thread: Terrible intermittent starting issues
    Glendale,CA
    E39 540i
    Hello all, I've got a terrible issue with my 05 645
    The car sometimes doesn't start. I turn the keys and everything lights up normally, but absolutely no turning of the engine. 15-60 minutes later it starts like brand new.
    ICOM gives me a power management code. Nothing else just power management.
    New alternator and no change. Starter is good. Battery is new. These three components are 100% okay. Key is also brand new.
    There are no retrofittings.
    Idk what else it could be. I change the relay as well. I checked all connections and wiring and everything is okay. All software is up to date on the car.
    I turn the key trying to get it to luckily start and eventually it works , sometimes I do it too many times and anti theft preventive manipulation kicks in and I have to realign the DME and CAS for it to work.
    I've never seen anything like this.
    Anyone have a similar problem?
    Glendale,CA
    E39 540i
    Update: I have an AHL code. And IHKA.
    Whatever it is, it is causing engine immobilization because the DME thinks the voltage is low when it's not.
    The integrated supply module, according to the wiring diagrams, has a START INHIBIT relay. Could my ISM module be bad?
    Jan 2016
    Ca
    2001 525it
    Ivm module
    May 2017
    ATLANTA
    05 BMW 645CI
    Quote Originally Posted by jclausen View Post
    Ivm module
    I have a similar problem and I took it to the dealer and I am also replacing the IVM module. Fixed!
  1. Intermittent starting "issue"
    By DocSean in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-22-2010, 01:48 PM
  2. Intermittent starting issue..540 6spd
    By DADx2 in forum 1996 - 2003 (E39)
    Last Post: 07-03-2009, 10:32 PM
  3. '95 525i Intermittent Starting Issue
    By blk84 in forum 1988 - 1996 (E34)
    Last Post: 03-25-2009, 06:22 PM
  4. Intermittent Starting Issue
    By UNVMYM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2008, 04:48 PM
  5. Intermittent starting issues.
    By iruleyou1 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-15-2007, 03:37 PM
