Results 1 to 6 of 6
Thread: removing water from under carpet
    Jan 2017
    orlando,fl
    2000 2.3l z3
    Rigged up a HF fan and some dryer hose to get a steady blast of air. Propped up carpet and blew it between the pad and the steel floor.
    Actually works pretty fast. it was soaked. after about 1 day running 95% of water was gone. (seat out) Tim
    Feb 2014
    O.C. Oregon
    E36-E367-E39-E53
    You have a few DSC sensors sitting right there. Not a good place to store water
    ​~Mike
    Jan 2017
    orlando,fl
    2000 2.3l z3
    Yeah- Youre tellin me ! Seems like those sensors are like 1000$ Don't want any more stinking water under there......
    How come somebody doesn't make a plastic tray to bolt on the floor under the seat just to catch water. (with a lip around the edges
    and sealed at the seat holes) like something weathertech makes. maybe even have a drain tube that goes through the floor to outside.
    Will look to see if weathertech makes one and if it goes under seat as well as foot area.
    Tim
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by fairchild View Post
    Tim
    It'd be easier to find/fix where the water is leaking in. While I have worked on cars that had previously leaked water in__a coupe that a bodyshop crook left the auto-drop window functions disconnected comes immediately to mind__given proper maintenance, they don't leak much, if at all. I've had a '99 and an '01 since 11/00 and 08/01 respectively, and their floors have never been wet.
    My '57 Austin-Healey, on the other hand...
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    ... How come somebody doesn't make a plastic tray to bolt on the floor under the seat just to catch water. (with a lip around the edges and sealed at the seat holes) like something weathertech makes. maybe even have a drain tube that goes through the floor to outside...
    Because the water from no leaks would drip into a tray under the seat. Some leaks might drip onto a Weathertech floor liner in the foot well. But most leaks travel into the carpet along the metal body underneath.
    Drip leaks:
    - A-pillar (might drip onto WT floor liner)
    - Elephant nose (drips onto console carpet)
    - AC drain (drips onto console carpet)
    Leaks that saturate from below:
    - Door membrane
    - Convertible top sealing frame
    BMW MOA 696, BMW CCA 1405
    Jan 2017
    orlando,fl
    2000 2.3l z3
    It is inside the shop on jack stands at the moment. The water leak problem is just another problem to be de-bugged. Summer rains will be on us before I know it.
    I was aware that most (or at least half) of the water leak modes are ones where the water snakes its way in behind door panels and through the bottom sills, ect.
    Will get to that problem shortly-----
    Have to try making an elephant nose un-clogger out of some Eastman plastic tube and an air gun. So I can fish it down the nostrils......
    Tim
  1. Removing water from spark plug wells
    By Needlesharp in forum 1999 - 2006 (E46)
    Last Post: 04-10-2019, 07:09 PM
  2. Best way to remove foam from under hood and trunk?
    By CMG in forum 1978 - 1987 (E23)
    Last Post: 04-24-2012, 05:37 AM
  3. water under carpet
    By mce36 in forum 1991 - 1999 (E36)
    Last Post: 01-24-2007, 12:13 AM
  4. How to remove water spots from leather
    By 2pak in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 12-17-2004, 09:03 AM
  5. what do i use to remove the adhesive from under badge?
    By Bmw Rollin' in forum 1991 - 1999 (E36)
    Last Post: 08-01-2001, 12:09 PM
