Results 1 to 8 of 8
Thread: Tie rod arm/lever
    Sep 2010
    CA
    1985 635csi
    Tie rod arm/lever
    I'm replacing my control arms and one of them is stuck and won't budge even with a press. That leaves me with purchasing a new tie rod arm. However the only parts I can find are '87 and up. My car is an 85 (32211125739) and a new one would be $100+. Are the later parts interchangeable? Will there be a difference if I replace both arms with 87 parts? Thanks!
    For an 87 >>>>
    http://www.ebay.com/itm/BMW-E24-635C...q5f0oA&vxp=mtr
    Jan 2015
    Berkeley, CA
    '85 M635, '00 V70R
    Tony, have you tried giving the tie rod arm a few hard blows? I just did this same thing on mine and was in a similar situation. I had mine under pressure for 24 hours while subjecting it to wd40 and it didn't budge. The next day, I gave a few angry blows to the side of the tie rod arm and when I put it back in the press it popped right out.
    baton rouge, la
    1988 e24, 2000 e38
    BFH works every time.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    A little propane torch from Home Depot has bailed me out numerous times (assuming the ball joint that is stuck is being replaced).
    Rob E3
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Two good sized hammers. Put one on one side and whack the other side hard. It should free it up, but I will say mine were so badly stuck it took over 2000 pounds of pressure with a press to bust them loose
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Jun 2005
    Texas
    E21, E24, E34, E46
    I don't know what the difference is between early and late E24, but I can tell you the only difference between an early E28/24 and an E34/32 is the width of the locating key (and the strut has a correspondingly wider groove to fit it). Other than that, there is no difference in the geometry. One could assume that's also the difference in early and late E24, but assuming doesn't always work. Of course the different size keys prevent interchanging them, and altering the keys would most likely be worth more than $100.
    Dec 2007
    Gilbert, Arizona
    6/83 1984 745i
    Does the hammer need to be gold BP )
    alpinweiß on anthrazit buffalo 1984 745i, 2014 Fiesta ST, 1984 635csi 1986 635csi 1987 L6 1999 M coupe 2002 M3 1995 325i 1976 200​2, 2001 996 TT 1994 850 T5 wagon 1998 GTi VR6 1983 scirocco
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Dan, I can't believe it took you that long to answer! How's that 745 runnning??
  1. WTB early tie rod arm
    By Bert Poliakoff in forum 1976 - 1989 (E24)
    Last Post: 03-04-2017, 08:08 PM
  2. does inner tie rods arms mean..
    By cheebs in forum 1992 - 1999 M3 (E36)
    Last Post: 02-15-2011, 04:27 PM
  3. Replies: 3
    Last Post: 05-05-2004, 02:48 PM
  4. Control arm/tie rod assembly writeup, with things the other guys left out
    By Blazin95Red325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-07-2004, 07:24 PM
  5. What tools to install tie rods and control arm bushings?
    By DOO in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-01-2003, 05:31 PM
