Results 1 to 3 of 3
Thread: Bracket on cylinder head won't fit! Help!
    May 2016
    Florida
    1993 325i 1990 325i
    Exclamation Bracket on cylinder head won't fit! Help!
    Purchased a rebuilt cylinder head and the bracket wasn't on it. Tried to put it on and won't fit flush with the head, how should I install it? 601542_x800.jpg
    Jan 2016
    Ca
    2001 525it
    The bracket fits all m20 e30's there is a pretty good video of this head Assy search removing camshaft m20 BMW in the video he is assembling the head after the rockers and shafts are in installed he is tapping that bracket in
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    it might stick a mm above the casting but as long as the shaft are locked in the correct orientation (leg sit into the slot and shaft oreinted to allow rocker retainers and oil flow to rocker) and the lock wings are touching ontop of the shaft (fully seated in the vertical direction) and the valve cover doesnt touch (with gasket of course) you are good to go
  1. Need help on cylinder head removal for HG replacement..
    By amcink in forum 1991 - 1999 (E36)
    Last Post: 08-05-2012, 12:53 PM
  2. Trouble pulling cylinder head off engine block. Help!
    By e39528iM in forum 1996 - 2003 (E39)
    Last Post: 04-23-2009, 05:01 PM
  3. OEM clear sidemarker won't fit HELP!!!!
    By e36325is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-06-2006, 08:19 PM
  4. Help with an E8 torx bolt on cylinder head
    By turnerNCM3 in forum Forced Induction
    Last Post: 07-23-2006, 07:09 PM
  5. Cylinder head? VANOS or not? help
    By skete13 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-11-2003, 09:52 PM
