Hello. My wife's car has developed a gremlin. Today when you approach the car and get within key fob distance, the car unlocks without touching the door handle or the unlock button. You can also hear the drivers side rear door sound like the door is constantly unlocking. You cannot lock the door by pressing the button. The work around so far has been to unlock the car from far away and lock it also at distance. I'm going to take it to the dealer but was hoping maybe someone has a solution before I go???? Any help is appreciated. I did pull the negative battery terminal to try to reset it but that didn't work.
Sounds like a problem with the door handle. It seems to think your hand is always grabbing the handle, so as soon as the remote is in range it opens.
Smart keyless go system?
I have the same problem on my 2014 750li. did you get it fixed?????
