Results 1 to 17 of 17
Thread: Looking for a bolt or reusing an old one.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Car: 1997 M3
    I'm installing adjustable lower control arms and I'd like to use non-eccentric bolts and nuts. There's no real significant or functional reason for going with this over reusing the old hardware other than that I'd like to go with "standard" hardware because it's no longer adjustable there and the new control arm outer forks may be a little thicker than the OE ones possibly requiring longer bolts.
    Digging through realoem.com I see that the eccentric bolt (item #10 pn 33326863853) is an M12 x 1.5 x 82mm.
    The inner lower control arm bolt is very similar (item #14 pn 33171090824). It is shorter by 2mm but also has a washer on it, effectively making it just a bit shorter (not sure by how much, which is obviously dependant on the thickness of the washer).
    A few questions:
    1 - Can I use item #14 safely? In other words, will there still be enough threads for the nut to screw on to?
    2 - Should I instead go with item #13 (pn 3332109? It's 6mm longer but has a washer reducing it to being about 4mm longer (just a guess).
    3 - Source bolts, nuts, and washers locally from a hardware store like Ace Hardware?
    A couple of things to keep in mind:
    A - The adjustable control arms going in are SPC brand. I'm not positive at the moment since I'm not home to measure them, but I believe the outer fork that gets screwed to the trailing arm assembly (knuckle?) are probably thicker than stock control arms.
    B - The OE bolt and nut combo also use a washer, which may throw off measurement estimations.
    I apologize for the size of the pictures and any typos, I'm doing this on my phone, as I don't have access to a computer at the moment.
    Thanks in advance!
    Jan 2016
    Ca
    2001 525it
    Don't by any suspension bolts from ace hard ware just order the factory bolts you are making this way to hard.
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    I would go with #13, but then again it's hard to judge without you controls arms in hand. Why not wait till you physically have them then take your measurements and decide. But yea don't use cheap hardware from lowes etc!
    I just got all my new genuine BMW bolts and nuts for my rear control arms and such.
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I did the same when installing my SPC arms. I didn't want to retain the eccentric bolt considering that was no longer the method of adjustment.
    I reused the upper inner bolt and replaced the eccentric bolt with one of similar length from Lowes.
    Nothing wrong with using hardware store hardware lol; just get similar grade/class bolt as OE and youll be just fine.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by rajicase View Post
    What I'm leaning towards is getting the upper inner bolt and nut (#13 & #12). My father's got a parts car at his shop I may have to rummage through if the rear end is stable enough (crashed car). Otherwise I'll get equivalent hardware from Ace for the time being in the appropriate grade and then switch it out later on if it becomes a problem.
    Related question: Should I use Loctite on the threads of the inner/outer arms bolts and nuts? If so, I'm guessing I should go with Blue?
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    I have never used blue locktite ... we always use red, but I also have big guns
    The only place we use locktite is on the rear damper lower bolt. The rest, just torque to spec (81 ft-lbs in this case, I believe).
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Ah, yes you're right. I forgot, these are locking nuts. Red on the shock bolt? I've got an Ingersoll Rand air impact gun for heavy stuff, I think that should do fairly well against red, but does this part really warrant needing red?
    Feb 2012
    1995 BMW M3
    Ive never loctited the rear shock bolt...
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Neither have I, that's why I'm curious to hear about it.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by LockDots View Post
    I've had it loosen up on track ... maybe it was not torqued to spec, but since then, I just Loctite that one bolt.
    Sep 2013
    New York City
    1986 325es
    Personal recommendation
    boltdepot.com
    15187 x4
    7744 x8
    15282 x2
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Scotch is a racer. Track cars expose weaknesses and issues way more than street cars. I have just a street car but in 12 years I have lost a rear lower shock bolt once and found one loose once. But I still don't lock tite since I don't track.
    Trumbull CT
    1998 M3 Vert, 1992 318i
    Agreed, though hardware stores often don't have the graded bolts you're looking for.
    I'm fortunate that the storefront for www.nutty.com is a couple miles away. Those guys have EVERYTHING (and good shipping prices if you're not close).
    Caprica Junkie
    Charlotte
    2012 GTI
    I'm pretty sure when I did it I reused the eccentric bolt but left off number 11, haven't had any issues.
    97 M3 - SCCA TT Prepped
    17 F150 - Tow Pig
    05 S2000 - Sold
    88 325is - S52 powered - Sold
    95 M3 LTW Rep - Death by Altima
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Figured I'd update the thread for a little closure for future searches.
    I ended up using a Metric grade 10.9 (standard grade 8) M12x1.75x100 bolt and nylon locknut. 100mm is just a bit long as it sticks out past the nut about 10-15mm, but I can always cut it down if it ends up being a problem. That being said theres no reason it should ever become a problem.
    Apr 2006
    ORD
    4Runner/911
    Why didn't the control arms you're using come with new bolts?
    Turner's, which I used did.
    1988 911 - Carb'd - Twin Plug - 3.6
    1999 SL 500
    2016 4Runner TEP - Gone
    1995 M3 - LS2 - Gone
    1998 M3 - Gone
    1991 M5 - Gone
    1993 RS America - Gone
    1995 M3 - Gone
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    I'm not sure. It wasn't tough to source new ones at least.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  1. Looking for a nice E36 M3? My old one's for sale at a dealer...
    By BimmerDawg in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-17-2006, 01:22 PM
  2. Looking for a hood out of an E36 M or non-M 4-door.
    By inkacola in forum BMW Parts Wanted
    Last Post: 03-11-2006, 09:44 PM
  3. Looking for a new or used Bavarian tri-flow exhaust
    By wicked in forum BMW Parts For Sale
    Last Post: 05-15-2002, 12:44 PM
  4. looking for the stereo details on an E28
    By Atticka in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-10-2002, 10:22 AM
  5. looking for a '92 or '93 325is, typical problems?
    By LuncanDunc in forum 1991 - 1999 (E36)
    Last Post: 07-13-2001, 02:08 PM
