I've been having some crankcase vent issues lately. I hooked up a gauge and saw 4psi in my crankcase while under boost! I decided to redo my system since the exhaust scavenge never seemed to work great for me and this is what I found when I removed it! The inlet port was totally clogged making it useless. The before pic is when it was clogged and the after pic shows the port after I hit it with a wire wheel. This isn't something I would have thought to check before...17439876_10156018219289126_1414382431_n.jpg17440186_10156018218804126_1294851044_n.jpg
Does it work well when it isn't all cruddy?
Mine works great. Most people don't install them at the correct orientation.
Detailed explanation would be much appreciated!
If you look on google images, there are a ton of people doing it incorrectly. When I rev to 3-4k there is major suction. Also be sure to run a check valve. It isn't included on the Vibrant setup.
Generally speaking, you will not have back pressure in the exhaust free revving or even under load at 3000-4000 rpm with a decent 3 - 3.5" straight through exhaust. This will not be the case above that. You will find that you will have ~2 psi back pressure or more depending on size, bends and components in the exhaust. I tried a bunch of locations without success.
Ok, thanks! There was a big thread on here a while ago, and one guy was adamant that it should be installed backwards from your drawing. Proof is in the pudding if yours is working well that way. Is that the way Moroso shows to install them?
I definitely had it installed right. Another important part of it is the location in the exhaust. Most people have the best luck putting it on the outside end of a bend. I didn't have a check valve because I was worried about restricting the flow. with the hole blocked up with the crud it was just pumping exhaust into my crankcase and made the pressure so bad that my turbo was blowing oil past the seals in both the intake and exhaust. My new setup uses a a catch vent into the filter for vacuum. It work much better than my scavenge ever did.
I use the Moroso setup. It's super cheap. TRM sells it. If I was to do it again, I'd probably go with the Virbant setup because the ventrui piece can be removed from the exahust I guess in the event of the OPs situation.
So you run the can to the exhaust and it fills up the container?
Yes (by fills up I mean like maybe a teaspoon of oil in 5-10k miles)
