Results 1 to 25 of 30
Thread: Loosen Crank Bolt / Starter
    Aug 2008
    New York, NY
    BMW 540i
    I have read on posts on other forums that people have loosen the crank bolt with a bar on the crank bolt and cranking the motor over with the starter. Anyone try this? Does it work?
    Thanks,
    Frank
    1997 540 / 6 Sport, 2001 540 staggered rims
    Suspension = Bilstein B8 Performance Plus Struts, Xeon headlights & fog lights, LED tail lights, Evo short shifter, Custom air engine intake, 3 inch dual exhaust hollow cats,NGK iridium spark plugs, removed -clutch delay valve
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    "worked for a guy or two once" and "not a stupid" are 2 separate things.
    Highly inadvisable. And i'm surprised it works, given how hard that bolt is to loosen. Just buy the eBay knockoff version of the crank holder tool and get a huge ass breaker bar from harbor freight.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    United States
    02 525,01 X5,99 323IC
    I would love to be standing 10ft away when someone tries this ingenious method..........it would be hilarious. Grinder has given you sage advice, I think the CORRECT tool is about $20, well worth the money and much safer. But, like many shade tree's on here, let us know how it goes when you ignore his direction.
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    I accidentally did this on an m20 once after adjusting the valves. Left the wrench on the crank bolt after turning it over by hand a few times, my friend turned on the car and wack! It destroyed the water pump, stopped on the frame rail, and loosened the crank bolt. Great learning experience. That day lasted longer than I expected. I'd never do it again.
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
    Aug 2008
    New York, NY
    BMW 540i
    Sounds like it works but not advisable. I have the pin for the flywheel to lock the motor; i'll try that with large breaker bar with pipe.
    Thanks,
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    That worked for me using a BMW brand pin, but I was lucky. Sometimes they bend. Better to only hold at the front pulley for cracking the bolt free. After cracked, put the pin in to lock tdc.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    You do NOT want to use the flywheel pin when loosening the crank bolt. Get the proper crank holding tool.
    1995 525i 5-speed - Thread
    San Jose, CA
    1997 BMW 540i 6 speed
    Yes, the flywheel pin is intended for timing only; it will not withstand the torque necessary to loosen the bolt.
    Apr 2015
    paradise
    the shinny one
    reminds me of the time a HS buddy asked to borrow my harmonic balance puller for his 454 nova.
    when I arrived, there were several dents and scraps running across the hood of his old man's buick and a large gash in the garage wall.
    my buddy said: I got it most of the way off with a regular puller, then started the engine thinking it would just fall off.
    turned out to be the outer ring of the balancer he was pulling off.. it flew out of the engine compartment, landed on the buick and just kept going.
    Oct 2014
    NE
    2000 740IL
    breaker bar with jack handle on it, op.
    Aug 2008
    New York, NY
    BMW 540i
    Interesting i have read that there is less force at the flywheel. Seems others feel this is not true. I'll look into tool to hold harmonic balancer pulley.
    Thanks again!
    Too bad these posts don't have the like button as FaceBook does!
    Mar 2010
    There is , purely because of the diameter of the FW. But all above is correct as that doesn't compensate for the tremendous force needed vs the teensy pin. I saw a sheared pin just a couple months ago.
    2003 M3CicM6 TiAg
    Former:
    Aug 2008
    New York, NY
    BMW 540i
    Anyone have a work around other than me buying another tool? Or place online i can get pulley holder cheap?
    JimLev's Avatar
    JimLev is online now Artifically Aspirated Moderator
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    You don't want to hold the harmonic balancer, you need to remove it and hold the flange.
    Some have used a long piece of angle iron bolted to the flange with the other end resting on the ground or a block, depends on how long the angle iron is.
    Aug 2008
    New York, NY
    BMW 540i
    I have read this worked for others who have BMW's; not the 540.
    "Put your car in 5th gear, have someone hold the brakes, get a 1/2" drive breaker bar with ~5ft cheater bar and start pulling. If your clutch slips before the bolt loosens, then give the cheater bar quick and forceful pulls. This method hasnt failed me yet"
    JimLev's Avatar
    Sundance Mesa, NM
    I've seen a few 1/2" breaker bars snap at the joint.
    I use a 3/4" breaker bar with my floor jack handle on it.
    Aug 2008
    New York, NY
    BMW 540i
    I'll try the 1/2, if it snaps oh well.
    Question - If i am able to break the bolt free with out Pin in flywheel how does one the get the engine to TDC without re-tightening bolt?
    Mar 2012
    Lansdale, Pa
    Just resnug it and turn the engine to tdc compression stroke on cyl #1. Insert pin. Remove bolt.
    You'll likely break that 1/2" bar.
    Aug 2008
    New York, NY
    BMW 540i
    I'll try this tomorrow; should be fun! hopefully nothing will go flying!
    Oct 2014
    NE
    2000 740IL
    Quote Originally Posted by philly98540 View Post
    shouldn't even with jack handle over it....
    Mar 2012
    Lansdale, Pa
    Quote Originally Posted by mooll View Post
    Why not? Joint at end of breaker bar is not saved by the jack pipe. All depends on how tight is bolt is, and how good that 1/2" breaker is. That bolt is pretty tight.
    Mar 2010
    Quote Originally Posted by Franktea View Post
    Seriously bro? Try reading the actual replies you get. they can be surprisingly helpful sometimes.
    It's not actually a bank-breaking undertaking TBH.
    As other guys are saying. The V8 bolt is seriously tight. "duh, I found this post about a Honda 4 cylinder so bet that'll work here" is seriously barking up the wrong tree.
    It's a torque angle spec but final torque is up in the 300ftlbs range IIRC. And an original bolt with some corrosion around the head is gonna prob require well over the 'tighten a clean new bolt' spec to get it off. Which is why a 1/2" breaker bar is a joke. Guys have broken cheap 3/4" breaker bars trying to do this, let alone a 1/2".
    Best of luck w/ that.
    Do you have all the cam lock / timing tools already, or are you going to improvise on those too?
    2003 M3CicM6 TiAg
    Former:
    Aug 2008
    New York, NY
    BMW 540i
    Geargrinder not Honda see link below, do some research before you criticize; are you not open to other possible options?
    https://www.bimmerforums.com/forum/s...ELP&styleid=51
    Thanks for the positive feedback.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Just buy the proper tool, it's not expensive: http://www.ebay.com/itm/BMW-M60-M62-...38.m2548.l4275
    You can always sell it after your chain guide job is done.
    Jul 2012
    mitten
    525it,02 525it,73 2002
    $39 is cheap buy the tool.
  1. M50 Crank Bolt Questions
    By TCSpence in forum 1991 - 1999 (E36)
    Last Post: 05-13-2008, 09:04 AM
  2. after draining oil + coolant, is it ok to loosen head bolts?
    By yellowbullet in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-26-2006, 09:35 AM
  3. Crank Bolt.... Aaarrrrgggghhh!!!!!!!
    By DanThe in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-29-2006, 02:21 PM
  4. M50 crank bolt removal
    By Joshh in forum 1996 - 2003 (E39)
    Last Post: 09-23-2005, 05:05 PM
  5. Main Crank Bolt LOOSE !
    By TallKDR in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2004, 04:04 AM
