Yesterday I installed a set of Solo Werks coilovers on my 1994 325i and I also installed a set of shims to get an extra -1 negative camber up front. My tires are now rubbing on the springs up front. I have Style 17s on right now (7x15, ET 47). I tried some 8 mm spacers and it looked like they barely cleared but i didnt feel safe driving it with so much of the hub-centric lip being covered. So i was thinking of getting 15mm spacers. Anybody have experience with how much space you need with these coilovers and shims? Also, how can I tell if I have enough clearance?
Not specific to the brand of coilovers, but some good info..
https://www.turnermotorsport.com/t-w...s-encyclopedia
You just need spacers, 47 offset is very high
Sent from my Nexus 6P using Tapatalk
Yeah I have read through that and have learned quite a bit about spacers. Im just trying to figure out what size I need without having to rent the spacer kit. I tried an 8 and it looked like it would barely clear. So im hoping that 15mm will be good. And then with that i will have a hubcentric lip on the spacer, so i will feel better about that.
Im hoping to get some 8x17s in the future with much less offset. But with this setup do you think that 15mm will be enough space?
AFAIK, if it clears at all you'll be okay. I ran my wheels with very little clearance between spring and tire for months and had no issues. That being said, I think the 15mm would be better as long as your wheels still fit inside your fenders (pretty sure it will).
Remember that you need extended lug bolts to match your spacers!
1993 E36 325is
2003 E46 325iT
SpeedHunters feature: http://www.speedhunters.com/2018/04/...t-dtm-tribute/
APEX feature: https://www.apexraceparts.com/blog/m...-arc-8-wheels/
35 or less should be fine to not rub on a 8 inch wheel .. i would go 30 to be safe.
Anything over 12mm on the spacer and you should be good. If you do less spacer you will need to get a set of hub extenders like I did.
CBlock
