Results 1 to 4 of 4
Thread: E36 318 - overheating -
    Mar 2017
    NY - LA
    BMW 840, BMW M5 e39
    Hi y'all. I'm new to the site. I have a love / hate relationship with this 96' BMW 318. I recently had to replace the radiator from a slight crack. I changed, that, thermostat,etc. it drove fine for day or two, than in NYC 19degree weather started overheating. I replaced water pump and plastic piece behind motor before firewall. After all drove fine for day. Than at night overheat. I've spent all day trying to bleed system. The heat from defroster blows cold now. Still overheating. Anyone have suggestion? I don't think head gasket is blown. I ran car 15-20 min trying to bleed system but no success. Had it up on ramp, open valve. Steam and some gurgling antifreeze. But it began to run hot. I'm all out of ideas.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 forum
    Jun 2010
    NY
    1997 328i
    I hope you turned it off right away when it overheated. Is the belt and tensioner in good condition?
    ?"open valve' "steam and gurggling"?? Explain better what you did an observed.
    Mar 2017
    NY - LA
    BMW 840, BMW M5 e39
    The bleeder valve. I bled system. Runs Good now. I noticed the breather hose ontop of cylinder is worn. Is it possible vacuum leak from there?
  1. E36 FS: E36 318 Engine Mount (new)
    By bmwsmurf in forum Engines, Performance Parts & Software
    Last Post: 07-27-2013, 09:04 PM
  2. E36 FS: SF Bay Area - E36 318 SuperSprint Exhaust - Dual Stainless DTM Tips
    By GQ_Style in forum Engines, Performance Parts & Software
    Last Post: 05-06-2012, 08:17 PM
  3. E36 (Feeler) 1997 E36 318-I
    By jps1995m3 in forum Whole Parts Cars
    Last Post: 01-03-2011, 11:23 AM
  4. E36 F.S. BMW M42 (M42B18) engine fits e36 318, 318i,318is, 318ti
    By chrisbec in forum Engines, Performance Parts & Software
    Last Post: 09-09-2010, 09:25 AM
  5. E36 Full e36 318 subframe
    By mattmoo60 in forum Suspensions, Springs & Shocks
    Last Post: 07-05-2010, 10:43 AM
