Results 1 to 9 of 9
Thread: ISTA-P cable for E66
    NY
    2006 760Li
    HI,
    after searching I'm confused, what cable do I need to get to be able to use ISTA-P with a 2006 BMW 760Li ❔
    I can use ISTA-D with a K+Dcan cable no problem but i can't get ISTA-P to connect ( nothing shows up in connection list).
    Black 1988 735i - (first car ) ** currently MIA
    Silver 2005 X5 3.0 - RIP
    Black 1990 750il - junked
    Monaco Blue 2006 760Li - Current
    Jul 2004
    Houston, TX
    36 Cylinders
    For a 2006, you need pin 7&8 bridged on your K+DCAN.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2017
    RU
    f20
    For what you need ista-p?
    winkfp
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    ISTA-P requires an ICOM. That is the only interface that will work with ISTA-P. You can use an emulator with a K+DCAN cable, but I strongly discourage this.
    NY
    2006 760Li
    I want to retrofit the aux port on the radio and upgrade software
    I ran network tool and tried ISTA-P loader ver. 4.9 that came with the download but it still doesn't work.
    Sent from my LG-H918 using Tapatalk
    Mar 2017
    RU
    f20
    Quote Originally Posted by sigmaes View Post
    You using icom?
    NY
    2006 760Li
    This is the cable I'm currently using
    Look at this on eBay
    http://www.ebay.com/itm/262799579850
    Unfortunately SSS program is too old to read my car.
    Is this what I need to get?
    Look at this on eBay http://www.ebay.com/itm/252423408782
    Is it necessary to get the whole kit?
    In the long term I want to retrofit:
    power folding mirrors
    Active cruise control
    Front and rear cameras
    Dec 2012
    North Carolina
    For coding, you can get away with a cable like you have. For upgrading I-level or flashing, you really need the ICOM or you'll brick the DME or modules on the fiber optic bus. Generally you won't notice much from updating software, unless it's necessary for an option you want to add. You can most likely code the options manually with NCS Expert and your current cable. ISTA-P can do all the work for you, but it's a far larger program and it requires an ICOM. If you are willing to spend the money, the ICOM is great. Since I bought one, I almost exclusively use that over my K+DCAN or bluetooth. The one you listed seems good, just confirm with the seller that it has a heatsink, it's important. Bear in mind that flashing or prolonged coding will require a strong 12v power supply, more than 30 amps. I built mine from a 1570 watt server power supply for around $20. I'm happy to provide details on the power supply if you want. Make sure everything is on point before using ISTA-P to prevent costly issues.
    NY
    2006 760Li
    Ok thanks for the info I think I'm going to invest in the ICOM, I have some old blade servers I can take a power supply from.
    I managed to get the D+kcan cable to work by deleting everything and starting over, unfortunately ISTA wants to update my software to do any kind of retrofit, I didn't even see the options for the AUX port or Power folding mirrors, and I can't add the "+NAUX" option to my VO via NCSEXPERT, so maybe I do need to upgrade the software after all, either way i think it's using the ICOM is just simpler and safest way if I'm gonna be messing with the car.
  1. Throttel cable for swap...
    By gobuffs in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-25-2005, 09:01 PM
  2. wich bowden cable for 97 vaders
    By skratch in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2005, 03:12 PM
  3. Cheap place I can buy 2 bowden cables for my seats
    By 328isguy81 in forum 1991 - 1999 (E36)
    Last Post: 04-23-2005, 01:19 AM
  4. FS: BMW e36 I bus cable for cd changer
    By mpower325 in forum BMW Parts For Sale
    Last Post: 11-06-2004, 11:02 AM
  5. Bad D-Link cable for CD changer
    By AndyZ3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-27-2003, 02:26 PM
