Results 1 to 4 of 4
Thread: Dead Driver's Door on 2007 750Li
    Mar 2017
    Montreal
    2007 BMW 750Li
    Hello all you BMW owners. I'm new here, but I hope to remain a while.
    I have a 2007 750Li with a dead driver's door. Nothing works on the door and I want to fix the problem. The module in the door
    has what looks like 5 or 6 plugs connected to it. The bottom plug has a large red wire, a large brown and a large black wire.
    Is the red wire supposed to have power to it when the car in running or when it is on accessory? There is not power at the red
    wire and I am hoping that is the problem. Another thing, if there is indeed power there, does it come from a relay or other module
    somewhere or is it powered directly? If it's powered directly, I can route a wire from an empty space in the fuse box and run power
    to the module.
    Another problem. When I bought the car a couple of weeks ago, the Bluetooth asked for a password and being a BMW noob, I used
    the old 1234 and this did not work. The problem now is that it will not pair now. When I go into the Bluetooth section of settings and
    press the iDrive button on Bluetooth, nothing happens. I am presuming it says active or a star or something will appear next to it.
    I unplugged the Bluetooth module yesterday hoping it will reset itself.
    Many thanks for any help given.
    Ian
    Apr 2017
    Shenzhen, China
    2003 BMW 745Li
    "dead driver's door", do you mean that the door cannot be opened by key or handle ?
    Jan 2016
    Ca
    2001 525it
    Check fuses first
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Bluetooth PIN is located either on a sticker in your manual, or if the manual is AWOL, look behind the left rear cover in the trunk and the sticker on the unit will have the 4-digit PIN printed on it. Just went through the same thing with my B7. Took all of 1 minute to get it cleared up.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
  1. Replies: 1
    Last Post: 02-15-2012, 12:54 PM
  2. Driver's door on my M3 Vert keeps coming loose
    By e30hijinks in forum 1991 - 1999 (E36)
    Last Post: 04-28-2010, 02:04 PM
  3. Fog lights on 2007 750Li are not white
    By scottsalisbury in forum 2002 - 2008 (E65, E66)
    Last Post: 03-29-2010, 03:27 AM
  4. wtb window regulator for driver's door on a e39 2000 540i
    By doktor84 in forum BMW Parts Wanted
    Last Post: 02-08-2009, 10:25 AM
  5. Dammit - Driver's door on race car is stuck closed.
    By nick325xit 5spd in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-28-2006, 12:50 AM
