FS: 2013 Aluminum RNR 18 Foot Open Trailer - Loaded
Selling my beloved 2013 aluminum open trailer made by RNR. I used this trailer for the last 3 years to haul my BMW M3 track car to tracks around Michigan and Ohio. It is in excellent condition, tows beautifully and has all the creature comforts you want in a top quality trailer. The trailer is loaded.
Also for sale locally: https://detroit.craigslist.org/okl/tro/6051381723.html
Located in Milford, MI
No PayPal; cash or cashiers check only
? Front tire rack for racing tires (adjustable height bar)
? A-frame tool box made from diamond plate texture aluminum with internal battery box, full size 12volt battery and charging quick connect jack
? 12V electric powered tongue jack (4,000# bulldog)
? 12V SuperWinch S4000 (4,000 #) powered winch with wired remote controller
? All aluminum tube structure and aluminum deck construction
? Dual (2) 3500# Dexter torsion axles
? EZ lube hubs
? Electric brakes
? Four 15 inch radial tires with aluminum wheels (Series 05)
? Extruded aluminum plank floor with beavertail
? (2) 6 foot ramps (stored at front to double as stone guard protection)
? Exterior lighting
? Led taillights
? (4) HD-D rings
? 2-5/16 inch coupler
? Spare radial tire with aluminum wheel
? Mounted spare tire bracket
? Removable fenders for low door height vehicles
Right rear of removable fender has a slight dent and broken weld. A replacement removable fender is about $150 from RNR.
If you want to delete the A-frame ATP tool box, Superwinch S4000 and power BullDog tongue lift (I will install a manual crank lift) you could delete $500.00.
GVWR: 7,000#
Weight: 1,250#
Weight Capacity: 5,760#
Overall length Tip of Tongue to Rear: 22 feet
Bed Length: 18 feet
Bed Width: 82"
List Date: 3/21/2017
For more info, click here to view the original listing: FS: 2013 Aluminum RNR 18 Foot Open Trailer - Loaded
This item is no longer available.
Sweet rig!
I'd be interested in the Superwinch S4000 and power BullDog tongue lift for my Featherlite 3110 if you're separating.
Dave
'18 RAM 2500 Laramie Cummins
'15 Pure White VW Touareg TDI
///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
///'72 Chamonix 2002 (Restoration project)
***sold as listed***
