Results 1 to 25 of 37
Thread: Planning on Doing Valve Cover Gasket next weekend
    Windy City, USA
    2010 750li & 2008 X5 4.8
    So I plan on doing my valve covers next weekend and was wondering what else done be done in there while I have it open. Unfortunately I won't have any help so I will be doing the job solo, but I think I will take my time and be ok.
    Oct 2014
    NE
    2000 740IL
    You shouldn't need any help...
    replace the upper timing cover gaskets ($12)
    Windy City, USA
    Quote Originally Posted by mooll View Post
    When you say upper timing cover gaskets are you referring to the vanos seals?
    Oct 2014
    NE
    2000 740IL
    Quote Originally Posted by roys740 View Post
    no,im referring to the upper timing cover gaskets.
    Windy City, USA
    Ok I think I can handle this. So I will focus on the upper timing cover gasket and valve covers. I will leave the vanos seals and lower timing cover gasket alone for now. Unless someone's else thinks otherwise.
    Also, which RTV should I buy? There's like 10 kinds from that same company. The blue and the black both seem like they would work well. The black one is for high temps.
    I need to draw myself a map or find an updated diagram of where I will be working.
    Oct 2014
    NE
    2000 740IL
    i have always used permatex black RTV , great stuff but the blk gasket maker stuff is all pretty much the same but im pretty sure permatex is number 1 brand
    even used it to repair dual 12" subs that had multiple tears in them lol
    Windy City, USA
    So after further investigation, reading information here in the various threads, bimmeboards, e38.org and youtube not to mentioned confirmation from a trusted forum member (Purplcty), I do need to replaced the gaskets on my upper timing cover and replaced my vanos solenoid seals. Just placed my order with FCP for everything. It shouldn't be too hard of a job for me, so wish me luck.
    Feb 2016
    Seattle
    2001 E38 740i Sport
    Replace 2 oring's from secendary air metal pipe. Nr.5
    http://www.realoem.com/bmw/enUS/show...diagId=11_2286
    If you want you can also permanently remove the injector clips from cable box. I ran my engine without those clips and there is no problem at all and future maintenance will be easier and faster.
    Feb 2013
    Houston TX
    99 528i Sp, 01 740i Sp
    Get the cam covers blasted and powder coated while they're off.
    Windy City, USA
    Quote Originally Posted by Nurburgringer View Post
    valve covers are being sand blasted and ran thru parts washer as we speak. Not sure if I can spring for powder coating right now. cant find local guy to do at a reasonable price.
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    A waste to powder coat them IMO, unless you're going full dress. Most of the VC's are not 'in the eye', just fronts and lower edges.
    Clean them good, ScotchBrite the bejesus out of them and shoot a few thin coats of your favorite color, hi-temp spray from any auto parts house.
    Spark plugs are easier while the covers are off, if they are needed. Good time to check the condition of your accumulator gaskets and heater hoses, too.
    Don't forget to 'preload' the upper timing covers when installing. If you don't there will be a gap at the VC's at the joint, and the timing cover gaskets will not compress completely.
    Beisan Systems website (M62TUB page) has a good write up.
    Cheers, and have fun!
    Feb 2013
    Houston TX
    nah it's ~$100 well spent. The castings have a pretty crappy surface finish. Wrinkle coating fills it in nicely.
    Assuming you have a reasonably-priced powder coating place nearby.
    One of the perks of living in Houston...
    Oct 2014
    NE
    2000 740IL
    ^ yeah, i agree. powdercoating em looks great
    was quoted $100 around here and that was reasonable.
    Oct 2005
    Silver Spring, MD
    Too many
    I'm doing the same job on my 00. I picked up a second set of valve covers at the the local yard, $18 each and I'm going to powdercoat them. I won't have to wait once the job is started.
    Sent from my SM-T817V using Tapatalk
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
    Windy City, USA
    Quote Originally Posted by Coupenut View Post
    I'm doing the same job on my 00. I picked up a second set of valve covers at the the local yard, $18 each and I'm going to powdercoat them. I won't have to wait once the job is started. Sent from my SM-T817V using Tapatalk
    Great minds think alike.
    Current: 2010 750 LI Sport (Ruby Black) and 2008 X5 4.8L Sports Package (Metallic Black)
    Previous: 2001 740 IL M-Sport package (Schwarz Black),
    2001 X5 (Metallic Black) &
    1998 740 IL (Artic Silver).
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Powdercoating seems like a good idea. I tried the VHT wrinkle black paint route and they looked GREAT for about a year and half. Now they are peeling :-(, and not for a lack of preparation.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    Powder coated mine nearly two years ago and they still look as good as the day I installed them. +1 on powder coating!
    '01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
    '99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
    '84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
    Windy City, USA
    Quote Originally Posted by 740iSport303 View Post
    what color did you go with? any pics?
    Jul 2016
    Chicago, Illinois
    are slow
    Go silver or gold.
    Tbh
    Windy City, USA
    Quote Originally Posted by XAlt View Post
    Go silver or gold.
    Tbh
    I'm thinking Silver, Black or even maybe a nice Blue but Gold, I am not sure how that would look.
    May 2010
    East Bay Area, CA
    I went black but I don't have any recent pics. But here is one before I wiped it down and replaced a seeping oil fill cap. But you can see, no bubbling or anything else.
    Rutland, Vermont
    I like the black too - especially on a black car and with the wrinkle finish.
    Richmond, Va
    03 M5 01 740i
    I used black VHT High Temp paint with no primer after sandblasting and mine have held up perfectly after 4 years and many miles.
    Rutland, Vermont
    Quote Originally Posted by Bigrobsbmw View Post
    I didn't use primer either. Just sanded really well with 80 grit sandpaper to get all the old coating off, then 100 for the final sand, and cleaned with lacquer thinner. Wish mine held up... :-(.
    Feb 2013
    Houston TX
    Unless you have an interesting exterior and/or interior color, spice it up!
    Mine is serious silver over gray so the bright red covers add some flash, bringing me a smile whenever I pop the hood.
    Reminds me of the red covers on my old 308 Ferrari too.
    Go for blue or gold
  1. Replies: 12
    Last Post: 10-14-2010, 07:02 AM
  2. need help... foregin object found while doing valve cover gasket
    By bkearney in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-01-2008, 09:09 PM
  3. Replies: 7
    Last Post: 12-06-2007, 03:37 PM
  4. in the middle of doing valve cover gasket help...
    By ryan2l in forum 1991 - 1999 (E36)
    Last Post: 02-05-2007, 05:31 PM
  5. I am failing on the valve cover gasket replacement
    By TheRide in forum 1996 - 2003 (E39)
    Last Post: 04-07-2006, 10:11 PM
