I have a broken hold down pin on one of my coil connectors. Can anyone tell me how to remove the 3 pins from the broken connector? Below is a picture of the broken connector partially dismantled and a close-up pic of the pins I need to remove.
broken connector
IMG_7556Sealant missing.JPGclose-up of the 3 pins I need to remove
I have tried using a small flathead screwdriver to push the pins out the back however they will not budge. I am looking for suggestions before I dremel the pins out.
2016 Macan Turbo
2009 Porsche 911 Carerra S (997.2)
2013 BMW 135i Convertible
https://www.turnermotorsport.com/p-1...uine-bmw-part/
URL shows how the pin looks like with those two holding pins from both sides.
The connector has two cutaways, you would need two small flat head screw driver's or you can use one screw driver but keep that tension on the wire while uncliping both holding pins the the pin will slide out.
https://www.youtube.com/watch?v=5rlXZUvhEsQ
Start Watching the video on 3:40, connector is different the the theory is same
To remove the pin you must first release the center mount from the body of the connector. Once this has been released you can use a suitable tool to push in the tabs on the wire connector. I have attached pictures below to show were to release the center mount.
Mark.
[QUOTE=BMWNTHZST;29641191]I have a broken hold down pin on one of my coil connectors. Can anyone tell me how to remove the 3 pins from the broken connector? Below is a picture of the broken connector partially dismantled and a close-up pic of the pins I need to remove.
More Pictures.
Mark.
[QUOTE=mandd;29642701]To remove the pin you must first release the center mount from the body of the connector. Once this has been released you can use a suitable tool to push in the tabs on the wire connector. I have attached pictures below to show were to release the center mount.
Mark.
Thanks Mark!
