Will an OBD1 throttle body work on an OBD2 engine? What's needed?
In for info
What is the advantage?
Yeah it will. You'd need a obd1 manifold to make it seal though. And youll need the whole obd1 assembly including the little arm and all.
1989 535i - sold
1999 M3 Tiag/Dove - sold
I have an obd1 manifold. Will the TPS, throttle cable and cruise control cable all work?
Tps, yes. Throttle yes. Cruise, unsure. I can take some pictures of a pair side by side for you to compare tomorrow.
1989 535i - sold
Here's a thread with some good pics of an OBD1 TB:
http://www.bimmerforums.com/forum/sh...6-M3-OBD1-SOLD
Here's one with 1 pic of an OBD2:
https://www.bimmerforums.com/forum/s...Body-OBD-2-S52
And another pic of an OBD2:
http://i62.photobucket.com/albums/h1...ps47bc319f.jpg
I think you might need to change the throttle cable and maybe the Cruise control cable.
But I'll sell the TB to you for a good price.
What is trying to be done here, why change from OBD2 to 1?
I have an obd2 motor in an obd1 car. Obd1 manifold and throttle body. The TPS works on an obd1 dme but never tried it on obd2 dme. Cruise works fine but I may have swapped the cruise assembly for another one. I cant remember but they are cheap and I didnt do any electrical work just cable routing.
