Results 1 to 10 of 10
Thread: Glove box strut/shocks??
    Mar 2004
    Silverton, Oregon
    E31-E36, E70, E46
    OK ECS shows one and they are over 170.00 Each..Is that possible!?
    Any hints on where to get these guys? If I need one, I need two, right?
    Are they interchangeable with any other car like an E38?
    thanks!
    B
    Brian A Silverton, OR
    '85 Euro 635CSi 5 speed conversion
    '87 L7
    '93 Euro M5 3.8
    '93 740i
    '94 850CSi #31
    '95 540i Msport 6 speed
    '96 M3/4/6 Euro 3.2l
    '03 M3 Cab
    '12 X5 3.5D Tuned
    Unofficial 1995 BMW 540i MSport registrar (please see Facebook BMW 1995 BMW540i Msport registry group to join or report a sale)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    04 Absorber 25N 1 51161954684
    05 Gas pressurized spring 1 51161948137
    realoem still shows the old cheaper price, but they went up in price drastically http://www.realoem.com/bmw/enUS/show...diagId=51_1035
    As far as I know, nothing else fits. On the German 7 forum somebody had ordered the 51161948137 from a shop made in 2014 and sold it for less than $50, but no longer available.
    The dampened gas spring pushes/swings the glovebox towards direction the seat when opened.
    I had collected some data on that
    Feder 51161948137 BMW
    SUSPANDER nicht oeffnen! Hoher Druck! = suspander, do not open, high pressure
    90518 Altdorf Germany
    51.16-1 948 137
    Typ 16-1 016 01505H 400N 40/04
    the other one
    Daempfer 51161954684 original BMW
    Bezeichnung auf dem Teil
    SUSRON SUSPA COMPART AG
    90518-Altdorf Germany
    5116 1954684 10/08 011 00288E
    I assume if you contact a company specialized on gas springs, they can supply something. just a quick google search found this company http://www.indgassprings.com/
    USA - Chicago
    Industrial Gas Springs, Inc.
    162 S. Pinnacle Dr.
    Romeoville, IL 60446
    Phone: 800.214.7034
    Maybe they need a sample or the info what I posted above is enough for them.
    SUSPA USA? Maybe that is the one which originally make them? http://www.suspa.com/us/products/gas-springs/
    Mar 2004
    Silverton, Oregon
    E31-E36, E70, E46
    Great info, thanks Shogun! (you must get tired of hearing that lol)
    I'm going to have to triple check both of these and make sure a junk car can't supply one or two. Man, you'd think as valuable as these things are, they'd at least last a while!
    B
    '87 L7
    '93 Euro M5 3.8
    '93 740i
    '94 850CSi #31
    '03 M3 Cab
    '12 X5 3.5D Tuned
    Jan 2005
    Japan
    Also check the boat outfitters, when my wife had her small Nissan I bought boat gas shocks with stainless brackets for the tailgate door, modified them a bit to fit, that was about 1/3 of the Nissan shocks, these pleasure boat outfitters have all the sizes, even stainless steel shocks etc
    examples here
    http://www.boatoutfitters.com/marine...as-shocks.html
    http://www.go2marine.com/category/14...for-boats.html
    ..special order gas springs to fit your application contact...... http://www.attwoodmarine.com/store/category/gas-springs
    Jan 2005
    Japan
    Mar 2022
    Santa Cruz, CA
    2017 340ix, 1992 735i
    Quote Originally Posted by shogun View Post
    I looked at the posts and I'm confused about this through translation. My 1992 735i when I open the glove box appears to only have one strut on the left side. I would love to get this fixed! I keep it locked now because it's so hard to close again once opened.
    Jan 2005
    Japan
    as per ETK yours should also have 2 http://bmwfans.info/parts-catalog/E3...m/glove_box_2/ probably you cannot see both, you first have to remove the cover inside
    #4 Absorber 51161954684 25N
    #5 Gas pressurized spring 51161948137 https://www.bmwpartsdeal.com/parts/b...161948137.html
    Mar 2022
    Santa Cruz, CA
    So is the idea to purchase these two?
    https://www.sodemann-federn.de/be-6-40-400-t
    then your glovebox is golden?
    Jan 2005
    Japan
    #5 Gas shock BMW 51161948137 is 400N and that is the Sodeman BE-6-40-400-T https://www.sodemann-federn.de/be-6-40-400-t, they also have a US website and that says Force (lbs) 89.92 https://www.sodemann-springs.us/be-6-40-400-t
    maybe you find the other one with 25N = Absorber 51161954684 25N in the aftermarket in the US cheaper ones as BMW price is crazy with MSRP: $225.44, check what is available, maybe even Sodeman have it https://www.sodemann-springs.us/ ,measure yours to make sure to find the correct length, also check what is written on your shocks. Johan has a good write up:
    Glove Box Shock Absorber Replacement
    Problem: When I opened my glove box it just fell open and dangled forward. Time to replace those gas shocks !
    There are two in the dash. One is an absorber to make the dash open gently downwards. The other one is a gas shock holding the compartment in the back or all the way forward in the direction of the driver.
    Fixing it: If you're just replacing the absorber you can do this with the compartment in your car. For the shock you have to remove the entire box.
    The absorber just clips off and the new one just clips on.
    When you're replacing the shock you have to take out the compartment.
    To remove the glove box:
    Remove the black plastic cover on the hinge (right rear side).
    Remove the torch charger socket and loosen the wires.
    The front part is held by the absorber and a strap. Unclip these.
    To loosen the rear part you have to open the plastic clips in the rear
    Then you're already to replace the box !
    Removing the gas shock is quite easy since it probably lost most of the pressure. You can just pry it off with a screwdriver. To replace the shock I first fitted the top, then using a screwdriver I levered the bottom into place using the nut on the support bar.
    Parts: These prices are for Europe when the article was written many years ago. Prices are in Euro excl. VAT or any other taxes.
    BMW part nr description prices once upon the time
    51161954684 Absorber 12.70
    51161948137 Gas shock 16.90
    When someone finds something fitting in the aftermarket, please post the details and links, many have the same problem.
    https://www.bimmerforums.com/forum/s...ve-box-removal
    http://bmwe32.masscom.net/johan/glov...box_shock.html
    Glove boxes and lower dash: http://bmwe32.masscom.net/johan/dash...al_v1.1-1.html
    Jan 2005
    Japan
    Found in my parts box a new old stock damper/absorber 51161954684 25N and measured it for those which look for an aftermarket damper
    length of the cartridge 9.30cm
    diameter of the cartridge 1.52cm
    length of cartridge with brackets 13.25cm
    length of damper expanded , end to end of bracket, 19.5cm
    brackets hole innner diameter 0.6cm = 6mm
    Written on the cartridge: BMW logo, SUSSRON, SUSPA COMPART AG, zip code 90518 Altdorf, Germany, 5116 1954684 10/08 01 00288E
    Fits: E32, E34, E52 Z8 , pics https://www.ecstuning.com/b-genuine-...h/51161954684/ https://www.drive2.ru/l/577164990574757690/
    with these details you should be able to find a replacement
  1. E34 glove box shock....
    By Road_Carver in forum 1988 - 1996 (E34)
    Last Post: 04-25-2020, 02:06 PM
  2. E34 WTB: Glove box struts??
    By Raziel310 in forum E34 Classifieds (closing soon)
    Last Post: 03-20-2012, 02:00 AM
  3. E34 Glove box strut
    By ragnuoy in forum 1988 - 1996 (E34)
    Last Post: 12-28-2010, 03:38 AM
  4. E36 Complete set of Monroe struts/shocks brand new in box
    By picabu in forum Suspensions, Springs & Shocks
    Last Post: 11-11-2010, 10:37 PM
  5. Replies: 13
    Last Post: 07-30-2009, 07:42 PM
