In that theme, I guess we know what it takes to get a 1 or 2J up to 400whp. What does it take to get an LS to that level? It gets pretty pricey I think, doesn't it? If I'm thinking correctly about it, that is heads and cam territory?
Bart (Inflame) is around 378whp on his 'GM hot cam'med LS1.
to get to 400wheel, you'll need 5.7 or 6.0 litres, a cam, a great tune, LS6 intake (or better), and valve springs.
with a swap, you're gonna run longtubes anyway, so I didn't bring that up.
I'm at 350wheel with a low compression 5.3 and poorly ported, and massively milled heads and a cam. My next set of heads alone should be good for at least 25hp. Stock rotating assembly LM4 5.3L.
always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
I have a stock LS2 and I have dynojet numbers at 370whp and 396wtq. I feel like that's basically "400whp". Most of the cheaper LS engines just need a better set of heads. Which sounds expensive but are much cheaper than you think because they don't have cams in them.
Yeah, it's really easy to make 400 wheel with LS3 or LQ9 heads, a cam and a good tune.
That's why you just start with an actual LS, or if you're going super cheapo then you just cut your hood for the truck intake haha. As far as working on the LS goes, at least in the E46 chassis it isn't terrible. Plugs are a bit tricky but totally doable. I was able to pull my heads and install ARP head studs with the engine in
I did ported and polished heads, oversize valves, cam, milled my heads and installed a thinner headgasket to bump up CR, and some small reliability stuff. I should be at about 400whp. Keep in mind I am at 5300' elevation. Cam choice also makes a big difference. Jeepster has a similar build to mine (his is a 383) and he made 480-490whp with his first cam, but didn't like the powerband so swapped it for a torquier one (same one I got) and it dropped the power to 420whp but with a much better torque curve. That's the NA route to 400, or you can spend probably $2000 piecing together a turbo kit, throw it on a untouched LM and make 500+ but who knows for how long.
aren't LS3 heads square port? From what I've always understood the LS6 (243) heads are the best OEM head for the irons and earlier LS
Plugs are tricky in the E46? They're stupid simple in my E30.
Pics for quick reference?
instagram @andyitslit
Apparently I don't take many pix of my engine bay. Here's the best shot I could find. Only bad one is (obviously) around the brake master. The passenger's side has nothing in the way.
https://www.instagram.com/p/-60Z7LzASe/
Damn, that's not bad. Chalk up one more mark in the positive column for the LS.
Last night after the discussion of the 400whp benchmark popped up, I started thinking about what I'm currently slapping together. If I don't blow up the slushbox right away, and start feeling like the setup might be somewhat reliable, maybe I will see what is required (in terms of bewstage) to make the 400whp ballpark.
I will have very little money in this bastard. If it could make a reasonably reliable 400 wheel (especially through the slushbox), then it would make any swap look kind of ridiculous unless the goal was bigger numbers, or more pleasing sounds/coolness. Of course that last part applies equally to both of the swaps this thread is about, since some people really love the howl of a JZ, and some people really love the roar of an LS. IMO, that truly is a personal preference thing with no way to argue about it.
If noise is the primary qualifier, nothing beats a strung out RB.
#justsayin
I honestly am VERY tired of hearing JZs and LS'. It's so mundane at this point. I'm still not bored of the RB sound. But I go for function over form no matter what.
Ignore the crap driving (3 year hiatus + 3x power = poo driving) in the video but here's my S52 turbo. I think it sounds sexy town.
https://www.youtube.com/watch?v=xw0PzpYFZfw
Got any exterior footage of that? I know Mike's car sounds fantastic on video, and I suppose yours might sound pretty similar?
tptrsn, you have to remember the E46 got dual vanos engines, where as the E36 was single and the single is much much better for adding boost and making power.
I mean they aren't bad by any means. It's the CX racing headers that make you get a tad creative, but its nothing 2 u joints doesn't take care of. I'd much rather do plugs on my LS then on a Subaru any day
I like the way my LS sounds
Nah... that was basically my only run before it caught fire (oil feed spewing on manifold) and I never drove that motor again. It's a long and sad story. I over engineered it. That's why I love my bone stock LS2. But a turbo M/S5x sounds like a turbo M/S5x.
Dual vanos motors are just bad from an engine management perspective. That's at least what kills it for me. You can just pick up a chip or a DME tune for E36s.
Don't bring subarus into this. That's like comparing a hang nail to a severed finger.
you mean this guy? This is Jeepster, Me, and Motion shredding the local cart track
Funny, I had no idea he was ever LS
this video does it no justice, but this guy is local and has the sickest sounding car. It's a something jay z
2JZ's sound kinda boring. 1JZ's sound better, tune it a little rich for exciting butt puckering backfires.
*wait for it* or skip to :35 seconds
I may be the minority on this but I like how turbo rotaries sound the most lol.
Some turbo rotaries sound phenomenal to me too! I just am not comfortable with knowing that I could build one, so I don't give them much thought...
I'll have to see if I can tune my overrun area rich and super retarded on the timing to see if I can get some 1980's F1 car bangety bangs with RomRaider, lol.
Depends on your budget and goals for the car, all 3 are great platforms. The LS will always have the advantage of early available torque due to displacement. If you properly gear a lighter car, with a properly set-up LS, than it will have power everywhere.
As for 1/2JZ vs m/s50/2 turbo, if you have an m/s5x already in the car, than a 1/2J is a total waste IMO. The BMW 24v engine is right on par with the 2J, especially an s52b32 turbo. If twins were easy to fit on an m/s5x, than 2 GEN-2 gtx2860rs, or 2 EFR 6758s would be absolutely nutty on e85!
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
https://www.instagram.com/p/mvfiQ1nc...ydomenechdrift
How you don't like that noise is beyond me hehehe. /jk I know different strokes different folks
