Results 1 to 3 of 3
    Jan 2017
    Long Island, NY
    2000 BMW E39 M5
    2008 BMW E70 X5 4.8i oil leak
    I recently had large amounts of oil leakage. I took it to the shop and they said it was the alternator bracket gasket. Why the hell does oil get there?
    Aug 2013
    Chesapeake, va
    2002 BMW X5 4.4
    Common issue with the 4.8, alt. Bracket is also the engine oil cooler connection adaptor, all of the oil flows through the thing. More than a couple of hours to change out a $1.00 gasket. Lots of info available in this forum.
    Sent from my SM-T337V using Tapatalk
    Jan 2016
    Ca
    2001 525it
    Oil pressure is going into it on its way to the oil cooler, I would replace the gasket and the cooler adaptor together
  1. 2007 BMW X5 4.8i- Oil level sensor?
    By Stairmaniac in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-13-2017, 12:53 PM
  2. 2008 X5 Repair question - oil leaks!
    By northwestdriver in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-06-2017, 10:19 PM
  3. E70 X5 4.8l oil leak info needed. -- thanks for anything
    By Ron97M3 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-10-2015, 08:09 AM
  4. 07 E70 X5 4.8i front differential oil refill question!!!
    By zhshb101101 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-16-2014, 01:15 PM
  5. Replies: 1
    Last Post: 05-24-2012, 03:21 PM
