Results 1 to 5 of 5
Thread: Air Bags fully extended? need help
    Dec 2008
    Scottsdale Arizona
    540iT 840Ci 850Ci 540i
    My 2000 540iT has been set at a nice lower ride height for the last 3 years.
    Suddenly the other night, one blade on the plastic cooling fan broke off, causing ZERO damage as far as I can see.......the dead blade was just resting in the left side by the oil filter housing.
    The motor had a terrible vibration until I stopped and took the fan off.
    But almost at the same time, the rear air bags went to full inflation pushing the rear up by 3+ inches......full extension
    Maybe the fan and the raised rear are co-incidence? I looked everywhere, and cannot find any damaged wires.......anyone have any ideas?
    There is a suspension height sensor on the right front wishbone which (I think) sets the height for the headlights, but does it also interact with the rear suspension height? If not, what has an effect of the rear height? The 2 rear suspension sensors seem to be intact, with no visual damage.
    Apr 2015
    paradise
    the shinny one
    Broken engine bay plastic is common and a sign of poor maintenance. You may want to replace the fan clutch at the same time.
    Air pump should have thrown an error code. A stuck air pump relay is the first thing that comes to mind.
    There is a PDF manual available on line (e39 air suspension pdf). A search of this forum will yield more information.
    Jan 2016
    Ca
    2001 525it
    I think the airbags have the sensor on the rear suspension
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yep. The SLS uses 2 - one height sensor on each rear corner, not the front one.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Apr 2012
    Trondheim, Norway
    2003 525d Touring
    I experienced the same thing on my wagon after I had some work done to the car. Full extension (not fun driving around with!), no errors or signs of mechanical damage. I disconnected the battery, then disconnected the air lines going to the bags to let her drop. Then reattached the air lines, connected battery, started the engine, and hey presto, back to normal ride height. Has been problem free since.
  1. Abs + air bag light always on help
    By Caz-01 in forum 1996 - 2003 (E39)
    Last Post: 11-17-2009, 08:22 PM
  2. Air Bag Deployed, Parts needed? & No start?
    By 15x in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-21-2009, 10:51 PM
  3. 1997 549i Air bag light stays on? help!
    By moman in forum 1988 - 1996 (E34)
    Last Post: 02-21-2006, 10:11 PM
  4. Replies: 5
    Last Post: 09-28-2005, 02:22 AM
  5. going to bag my ride need help with rim size
    By green bmw in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-22-2005, 10:37 PM
