Results 1 to 8 of 8
Thread: X3 Trailer Control Module
    Mar 2017
    Oklahoma
    2007 BMW X3 E83
    Hi there! First time poster here.
    So I just recently put a trailer hitch receiver on my 2007 BMW X3 (E83). Everything went smooth. My question is, what does the Trailer Control Module do?? I've searched everywhere on many websites and even called my local BMW dealership parts department and they didn't really know much more than "it communicates to the cars main ecu that its towing something." I would assume that it also gives power to the trailers brake lights.
    • Is that all it does?
    • Does it have a trailer brake controller mechanism?
    • Anyone have a feature list?
    If that's it, cool. If it does more, I'd like to know what.
    See below for part numbers
    • Trailer Hitch "Kit" - P/N 71 60 0 035 368
    • Electrical Kit - P/N 71 60 0 035 369
      • Trailer Control Module - P/N 61 35 6 955 253
      • Vehicle-Side Wiring Harness
      • 7-pin Trailer Wiring Connector
      • 7-pin to 4-pin Trailer Wiring Adapter
      • Hardware Kit
    Thanks in advanced for your help in this matter!
    If the premise is the same, I had it on my 2001 X5. It interacted with the air suspension to keep the vehicle level, and supposedly adjusts the braking Software so the cpu knows there's weight back there.
    Using Tapatalk
    Mar 2017
    Oklahoma
    2007 BMW X3 E83
    I appreciate the info you provided dano1200r. My X3 doesn't have air suspension but that's nice to know that it does more than trailer lights.
    I was just curious if anyone out in Internet land might have a detailed feature list or any more info on this unit and what it does?
    Dec 2018
    Fall Church Va
    2009 BMW X3 E83
    I don't have an answer to you question, but I do have a related question.
    I bought the same hitch and harness kit, and have installed everything but the Trailer control Module. Can you tell me where this is located?
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    Bill,
    I installed my harness kit with some help from youtube videos. I would suggest doing the same, however, the module goes below the floor panels inside the trunk, right behind the back seat. There is an electrical connector waiting there for the module. The other end of the hitch cable needs to go to the same place.
    Dec 2018
    Fall Church Va
    2009 BMW X3 E83
    Thank You Vinyldude,
    My harness is already installed, but I haven't found any youtube videos on the module, and could not locate a connection point in the rear of my 2009 X3. A BMW dealer in Chantilly Va told me I couldn't install this unit as it requires the vehicle computer to be recoded....Does anyone know if this is true? The closest Dealer to me is Alexandria, but I know for a fact, they are corrupt.
    Apr 2014
    Renton, WA
    Sorry, it was probably these instructions that I followed rather than a youtube video.
    https://xoutpost.com/articles/x3/bod...h-2006-x3.html
    Towards the end there are pics where the module goes.
    Dec 2018
    Canada
    2007 BMX X3 3.0i Manual
    Since there are very likely no signals being sent from the trailer (no feedback loop to the cars ECU on what the trailer is doing), it's likely very simple functions like the lights (of course) and maybe it uses more breaking as long as a harness is plugged into it from the trailer (but not likely a "interactive" setup).
    Something like:
    Checks if its plugged into the trailer harness yes/no
    If not plugged in do nothing
    If plugged in runs trailer lighting
    If plugged in possible different engine map? (for towing power) but less likely
    If plugged in possibly some brake assist? - also less likely since these cars have a tiny tow rating anyway
  1. E53 WTB: E53 4.8is air suspension control module
    By Jaybeast45 in forum BMW Parts Wanted
    Last Post: 05-28-2016, 05:43 PM
  2. Wtb: Control module for cooling fan (2007 x3)
    By jayharrell10 in forum BMW Parts Wanted
    Last Post: 02-27-2012, 04:19 PM
  3. How difficult to replace an X3's light control module (LCM)?
    By ckoblmil in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-17-2011, 10:30 PM
  4. E53 FS: INTRAX Control Module For BMW X5
    By dvs1 in forum Suspensions, Springs & Shocks
    Last Post: 05-03-2011, 02:11 AM
  5. Need HELP ! Temperature Control Module not working
    By JLee in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-04-2001, 04:07 PM
