Results 1 to 10 of 10
Thread: Starter Question of the Day
    Sciota, Pa.
    1987 BMW M6
    Sometimes the starter motor turns but fails to engage the flywheel. What is actually failing? And, is 30 years of good service enough for this starter?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Sounds like, if there is one, the Bendix drive is shot. This is what moves the gear on the starter to the flywheel so the teeth will engage
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Aug 2014
    Lutz, FL
    '85 635 CSi Euro 5sp.
    Here's how to R&R the starter on an M30:
    http://www.mye28.com/viewtopic.php?f=3&t=100967
    Dean
    Lutz, FL
    '85 635 CSi Euro #9402254
    '87 Spider Veloce
    '92 Spider Veloce
    '08 350Z
    Dec 2013
    Chicagoland area
    EXOTICS
    Also a possibility of chipped and broken, missing flywheel gear-teeth.
    Can be easily confirmed once starter is removed.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    If you are going to remove it, replace it with an sr441x, smaller, lighter, higher voltage....so if you ever need to replace it again, it will be easier (though from the sound of it, replacement will be done by whoever you leave the car to in your will).
    Rob E3
    Sciota, Pa.
    1987 BMW M6
    Quote Originally Posted by MIKYZZ4 View Post
    Gee, that sounds like loads of fun. I'll give it a good look and hope for the best.
    Thanks to you all for the info.
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Hey Ron how goes it?
    The lube in the solenoid is probably lacking along with the
    magnet that pulls the spinning gear into the flywheel.
    Make sure your battery is fully charged. A small drop in battery voltage can effect the magnet pull,
    especially going thru the crazy starting circuit that BMW used in those days.
    Good luck.
    Just a heads up-- the my e28 instructions is for an M30 engine, not yours.
    North Carolina
    '86 M635/'10 Clubman
    I'm probably going to replace the one in my M6 with an E34 unit. Need to start getting the car together...
    Sciota, Pa.
    1987 BMW M6
    Quote Originally Posted by 1986series6 View Post
    Good luck.
    I'm doing OK, surviving the winter, I hope you are well Bob. The charge on the battery is good and I did look at the E28 post. I have had the intake plenum off for other reasons so I'm good to go in that regard.
    Alright, half the job done.
    See ya @ "Idiotfest" 2017
  1. My Question of the day...
    By TJFitz in forum 1992 - 1999 M3 (E36)
    Last Post: 09-29-2003, 01:53 PM
  2. question of the day
    By Dj Waffelz in forum Off-Topic
    Last Post: 11-06-2002, 03:10 PM
  3. Idiot question of the day...
    By Guillermo in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-27-2001, 08:37 PM
