E38 bimmerfiliacs I need your help on this 1. Ive had this for a year and half finally want to install it. I want to know before I open up the fill hole and lose fluid will the parts I have are sufficient. I tried emailing the inventor of the dipstick and i have the instructions but not the parts list. Anyone else here install this??
1 bottle of ZF trans fluid
Transmission diptstick kit
Dipstick
All the fittings i have
Connected together
Here is my concern. The metal pipe is metal to metal with the fittings. I can totally see fluid coming out of the top. No???
Sent from my SM-N910P using Tapatalk
2000 740i Sport
When the dipstick is inside the tube the end rests at the curve of the pipe. So lets me believe the HOT fluid will be sitting inside the tube to the Dipstick readings. Shouldn't the pipe connection at the base fittings be sealed tight??
2000 740i Sport
I generally get concerned anytime the inventor of something doesn't reply with necessary details. I've never installed such a thing, but it sounds reasonable if he has the level on the stick calibrated to the trans and doesn't have it sticking out into the moving parts. If, during a dry run, the stick doesn't extend past the tube, you're certainly going to need to have fluid in the tube for a reading. For me, the question is when the car is at rest, how does the fluid rest in relation to the fill hole? For example, on my old 308, the gear oil sits right at the level of the bottom of the hole. If a stick were added that was flush with its tube, I'd get nothing. Just thoughts out loud
Sent from my iPhone using Tapatalk Pro
Matthew M.
North Carolina, USA
1997 840Ci | 2001 740iL | 1985 308GTSi Quattrovalvole
here are the INSTALLED pics from the instructions
2000 740i Sport
I have this installed. The parts you show are correct. The metal sleeve is a compression fitting that will seal the pipe and threads from leaking. Fluid does sit in the tube. The cable "dipstick" is calibrated to show the correct level when the car is on level surface running. It is best to check this a couple times to compare and average the readings so you don't overfill.
Mock up the dipstick before you open the fill hole. You need to get that metal plate put around the top end of the dipstick and it bolts to the back of the block on the passenger side near where the wire harness drops back behind the engine to go to the trans. It is hard to get that plate lined up if you get the dipstick bolted into the trans first, since the pipe is stiff and there is no give. You kinda have to go back and forth a little to get everything line up passively before tightening down.
Just have a clean pan to catch the fluid that comes out (you won't be doing this with engine running), and then you can dump it right back in once the dipstick is on. No biggie.
Wow well you beat me to it. Is that fluid in your photos a leak or residual fluid? The nut part that is around the tube part is the one that as you tighten down, presses the compression fitting in tighter to seal things up.
Here is the LINK to the website for the E38 Transmission Dipstick
http://www.meurosport.com/5HP24_Dip_Stick.php
2000 740i Sport
Also, make sure you don't leave the copper ring on the transmission when the plug is removed, since you have a crush washer with the dipstick parts.
oh wow...Glad someone has done it....No those are not my pics but from the instruction guide...So the pieces I have are designed for it NOT to spill...Nice
So I have to tighten everything up once the pipe is inside the banjo fittings?
great tip! thnx.. Experience any leakage?
2000 740i Sport
this is good, i just ordered mine. Hope everything goes well
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
there's a forum member here, gonna be making these in the spring. that's the plan , at least.
also OP can u tell me what those bolts u used on the trans are / what size?
thx
[QUOTE=mooll;29637073]there's a forum member here, gonna be making these in the spring. that's the plan , at least.
m6 x 22
2000 740i Sport
thanks but no i mean what bolts are those holding ur trans pan on ?
This looks like a nice mod. Any other benefits to it besides checking fluid? I am guessing you can add some this way too. Possible help in flushing? I have seen some guides that hook up to the lines. Filling might be a good option. Just put a large volume of fluid above and it should make filling it quicker and easier.
"Lead by example, follow by choice."
Lol sorry
Thought u meant the banjo fittings sizes. That picture of the pan bolts are not mine. I borrowed from instructions page. Now that its easy to replace the torx head bolts to hex head. All u need is 1 transmission bolt to take to hardwarw store and match the length and bolt size. Also look at the grade of the bolt. Appears to be an 8.5 stamped on 1 of those
2000 740i Sport
M6 x22
2000 740i Sport
The manufacturer of the dipstick IS a member here and on bimmerboard. His name is Thomas Meacham on Bimmerboard, but I cannot remember his handle here.
'01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
'99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
'84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
So the steps should be:
Take out the plug and catch the fluid that comes out.
Take the larger fitting from the kit with the copper crush ring, and install it in the transmission with the allen key wrench decently tight to have the copper crush ring seal against the trans.
Slip nut on the tube and then slip the sleeve on the tube. Set them into place as you wiggle the tube up into place in the engine bay.
Slide the supporting bracket onto the tube and position it in place where the bolt is at the back of the intake. Thread the bolt back into place through the bracket.
Once everything is lined up and doesn't feel like you're putting pressure on parts tightening them in, you can use a wrench to tighten the nut down into the trans fitting. It will compress that sleeve against the tube and the metal trans fitting.
Then tighten the bracket up top.
Immensely enjoy dumping your fluid back into the transmission through the dipstick
I don't think it has leaked. I do have a slow transmission fluid leak that when I briefly looked appeared to be the shaft selector seals that were leaking. I should get under and look more closely (it could be leaking, but I doubt it unless something loosened), but with a dipstick, it's easy to add fluid! (Haven't needed to yet)
Not that I can recall. It's a pretty skinny tube and just goes down the back of the engine. I can't remember how close it gets to the coolant accumulator pipe back there, because I generally remove the water pump when doing the valley pan or the coolant pipe o-rings.
Not that I can recall. It's a pretty skinny tube and just goes down the back of the engine. I can't remember how close it gets to the coolant accumulator pipe back there, because I generally remove the water pump when doing the valley pan or the coolant pipe o-rings.[/QUOTE]
Thank you ... have you sold your car?
1 step is You have to grind the transmission corner off with a dremel.
Wait! The tip was to remove the crush washer after removing the oem plug, now reuse it?
2000 740i Sport
