I took a trip to Minnesota with wife - 4 hours away and decided to take the e30.. yeah I married well...
Anyway - we get back from shopping and I popped the hood (engine running) to check vacuum, oil, and fluids and my voltmeter was pegged at 16-17 volts ( I have a gauge wired into the ignition coil to monitor the volts) I was a bit surprised as you know that is too high.. the car was warmed and the ambient temp was 34 degrees or so.. It was late - so I shut down the car and we went to bed.
This morning - I get up and go out to check everything (I brought tools and have my handheld volt checker) and everything is fine this morning - 13-14.5 volts to battery. Battery has no sign of damage. I have an interstate in which you can pop the tops off - but not sign of boiling or leaking..
I read on pelican forums if the regulator is broke - then you can get that kind of volts.. but I'm trying to reconcile what happened last night. My experience with alternators is that they are either good or bad - might this be a sign of one going bad? (at least the regulator..)
Should I but an alternator just in case - throw it in trunk?
Also - how long can a system overcharge until the battery gives out or explodes.. Does a guy have a few hours?
The auto parts stores will want the core, so just remove it and install the new one.
You feeling' lucky?
m
Good point - but they are easy to change. I think I have a 90 Amp.. but how do you verify?
I would not run that. An bad alternator will quickly leave you stranded. If it's fairly new, you can try replacing just the voltage regulator itself. If it's more than 4 years old, why bother? Just replace the whole unit.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
