Question, will this bmw 162 wheels fit a 2014 328i?
i'm considering buying this set.
thanks,
DoN
Technically yes. What tires are you using?
Sent from my HTC6545LVW using Tapatalk
technically?
I've been doing some research online, and it looks like these rims come staggered with 225 40 18 in the front and 255 35 18 in the rear. but i understand the f30s staggered tires' offsets are 5 offsets higher at 225 45 18 in the front and 255 40 18 in the rear. And the bolts on the f30 are 14mm and 12mm on the e90s.
I just wanna know if anyone has tried fitting an e90 wheels on a f30. i wanna get rid of those standard wheels on my f30.
Yes it will fit. Those tires will have less treadwall than the stock 225/45 and 255/40 but they will fit. The offset isn't an issue unless you're slammed on bags or something. You would also reuse your stock bolts
