2000 M Roadster, 93,000 miles.
Recommended radiator replacement?
Do not buy brand ......?
Thanks for any help.
There is an all aluminum one called "VSL". Never heard of them. Then there is mishimoto- then there is another more expensive brand which I cant remember the name---
Some of these are thicker I think.......
Having experimented with many of the choices out there, from the stock replacementsto the aluminum eBay specials, I am now switching all of my cars to Zionsville.
I drank the VSL Kool-Aid. It looked and felt well made, but developed a leak in one of the welds in less than 1 year. It was replaced under warranty by Mishimoto (VSL is no more) with one designed for an E36 so its not a perfect fit for a Z3. I sold it on eBay and installed an oem from Valeo from Turner. Its been going strong for 3 years now. (knock wood) Zionsville has a great rep but for a street driven car are overkill (IMHO) and way outside my budget.
Blue Ridge Mountains
1999 2.8 Z3 Coupe
Arctic Silver
There is some confusion on radiators, and other parts, and what BMW has done to the supply chain.
OE - comes from BMW, has a BMW logo, in BMW packaging
OEM - Does not come through BMW, and per contract, can NOT be made to the same specs as the OE part, nor even made in the same plant as the OE part. This means they are aftermarket, often China sourced, with nothing going for them except marketing.
Two decades ago, "OEM" meant something. Now it's just a marketing gimmick.
I have a VSL that is 8 years old and going strong. It will be coming out once Zionsville and I finalize the design and get the critter built.
/.randy
I've probably put in a dozen or so OE (sourced from BMW dealerships) radiators in other forum member's cars.
I've probably put at least two dozen Zionsville radiators in cars during the same period. The Zionsville aluminum radiators are probably the best you can find, as far as construction quality goes, and they offer a multitude of options, like aluminum shrouds, "puller" electric fan kits, aluminum reservoirs, and even oil cooler upgrades for the non S-54 engined cars.
If you want the best, call and talk to Dwight: (317)873 3216
Tell him the Randys sent you
I bought a e36 all Aluminum Radiator from Ireland Engineering years ago for the LS swap. Its held up 6 or 7 years of all track. About 200 hours total. The welds were a bit sloppy, but for the price, it is hard to beat. I will say most all the street parts are off my car so it may be that it will not fit a street application. But worth looking into. I can run the LS in 100 degree heat on track and it will maintain.
Dan "PbFut" Rose
My red coupe, the one that starred in the cooling system experiment thread, is now sporting the Zionsville "Fat Boy" E36 radiator with modifications. The picture they have on the website *right now* is my radiator. Not like, that is the one. A Fat Boy married to Robb's MM panel compliant oil cooler. Some changes were made after test fitting that one. We are now working on the design to make it clear the RMS blower pulley. You simply can't get more radiator in the stock sheet metal.
/.randy
I am currently in process of ordering new radiator from Zionsville and Dwights recommendation as best option was https://www.zionsvilleautosport.com/...p-cooling-kit/ with narrowed shroud. Is it "more radiator" than Fat Boy?
The Fatboy does not leave enough room for a puller fan. It won't even clear a RMS supercharger. And that oil cooler won't clear a MM undertray. Since I run without a puller fan and needed the shorter oil cooler (with AN fittings), the Fatboy was my choice.
/.randy
Zionsville is great but OE from BMW should be fine for you OP
Thanks to all.
Jim
Hi Jim - if you're still looking for a solid radiator, we carry the Zionsville brand. As some members mentioned, these are more performance oriented and built very well.
http://www.pelicanparts.com/catalog/...WATRAD_pg1.htm
-Dmitry
888.280.7799 | 6am - 5pm PST
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
You know, the mishimoto is just fine for the price. I have one and no complaints.
Had a very small weep and they sent me a replacement after I sent them a photo.
I already replaced it though, so if anyone wants a brand new mishimoto radiator let me know.
White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
I like Coupes.
So what is wrong with a "Stock" Radiator...yes there a plastic bits...but you replace it based on age, before your stuck at the side of the road...
It just that the OE radiator & cooling system has been known as under powered and as a weak point in the E36 platform. A number of things contribute to cooling efficiency fluid capacity, fin design, material, etc. If your car is DD then stock is probably fine, but for track or modified cars with superchargers or turbos a more efficient radiator can literally make or break your engine. Zionsville seems to be the best thus the $600+ price tag. Allot of guys have done the fan delete as well making a better radiator and water pump even more important.
New OE radiator along with this solved all my overheating problems on hot track days - http://www.bimmerworld.com/Cooling/O...Valve-Kit.html
2001 Steel Gray MCoupe - 147,000 miles and owned since new. MCS 2WNR suspension, Hotchkiss swaybar, poly bushings all around, cat delete headers with custom tune, 3.73 LSD, and Clownshoe Motorsports rear subframe reinforcement.
2014 Porsche Cayman S / 2022 BMW X3M Competition / 2020 Ram Rebel
When going the OE route, does it make sense to use the three row S54 radiator over the two row version used in other six cylinder Z3s?
Fake news. The s54 radiator is not three row. It makes no sense unless you are also using the s54 oil cooler.
Never mind--Randy beat me to it.
Yep. Exactly. I was talking about the ones you buy today. But even so, if after passing over two cores you still have enough extra heat capacity left in the air that a third row would do anything worthwhile, you have a design problem. Yes... it did something in the 1960's pickup with round tube copper . Radiator core technology has moved on since then. Maximize surface area first. The S54 without theoil cooler is less area.
/.randy
And nothing the OP posted suggested that he is doing anything more than normal driving...His original radiator lasted 17yrs and 90k+ miles. An "OE/OEM" replacement will probably last just as long be easier to install and cheaper
Tracking a car once in a while is also not going to strain the stock cooling system either, but past that your into all sorts of "track" related thing that need modification and or replacement. For me,depending on the track, 15 miles is the limit before a cool down lap as the oil temp gets over 280(ish). but that's hammering it's all the way using every rpm I can find so an S54 radiator + oil cooler is in the plans for this winter.
