Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Water pump bearing went. Holy smokes, 750's need to remove the Jesus bolt?
  1. #26
    Feb 2013
    The Motor City
    1997 750 IL
    tx JP,
    Well, I have the breaker bar and a regular socket, not impact. I have the dampener holding tool and the water pump here by Thursday. Oh yeah, a new bolt as well. So hopefully Thursday will be the big day. If I break the socket I will have to go hunting for a better one.
    ---- Processing Individual ----
    Z1XX Upholstery
    Seats front and back in Epingle / leather englishgruen,
    As Schl.Nr. B9EG.
    Front seat backrest in Montana Englishgruen (No. 8 174 861)
    Other interior equipment as for Volleder Nappa englischgruen,
    Schl.Nr. P5EG
  2. #27
    Oct 2014
    NE
    2000 740IL
    Quote Originally Posted by jblacky View Post
    Got it from my dads coworker who kept great records of everything done. He was the second owner and bought it at 30k.
    nice
  3. #28
    Mar 2011
    England
    750iL; 330Ci cab; 5GT
    The V8 engines use a much higher torque than the V12s - IIRC 440Nm rather than 100Nm + 60 + 60degrees, so you would need that kind of leverage.
    XBOSS its not how thick the breaker is, but how much leverage you can apply. 20" is half as long as needed, so will require twice the force... Good luck with the hernia
  4. #29
    Feb 2013
    The Motor City
    1997 750 IL
    Quote Originally Posted by chrisn7 View Post
    you missed the part where I said I will be putting a jack handle on it.
    Z1XX Upholstery
    As Schl.Nr. B9EG.
    Schl.Nr. P5EG
  5. #30
    Feb 2013
    The Motor City
    1997 750 IL
    I ended up using a 3/4 drive breaker bar with a 1/2 adapter to a 1/2 drive 27mm socket. I know it is a lame setup but locally there are limits, seems like all the stores these days move the low selling item,s to online ship only.
    Anyway, the bolt is loose and I did not even use an extender bar. Off the top of my head it felt like around 350 ft lbs.
    Z1XX Upholstery
    As Schl.Nr. B9EG.
    Schl.Nr. P5EG
  6. #31
    Feb 2013
    The Motor City
    1997 750 IL
    Back on the road. Job notes:
    Bolt was not too hard to pop loose. Maybe 350 ft lbs max
    I used a mold release spray on all the hoses and gaskets so everything slid into place which is real important for the back two pipes off the water pump and the water pump gasket it'self which is an outer edge compression style and not the usual gasket water pumps have.
    The belt tensioners were a joy to deal with. Very easy to remove everything and very easy to set the belts back up.
    When you go to pull the dampener off of the crank be ready for it to fall off because it goes from super tight to in your hands in a snap and it will fall off the crank after a very short sliding distance forward.
    Easy job overall.
    Z1XX Upholstery
    As Schl.Nr. B9EG.
    Schl.Nr. P5EG
  7. #32
    Northwest Ohio
    2001 750iL
    Sorry Xboss. Late to the party. Glad to hear you got it done without a problem.
    I had to do mine last year. Not too much of a pain like you said.
    2005 X5 4.8is (DD winter) * 2001 750iL (DD summer) * 2001 Ford Excursion 7.3 L <> 2005 X5 3.0 * 2003 X5 4.4i * 2009 X3 3.0 * 2009 X5 3.0 * 2007 Toyota Avalon Limited
  8. #33
    Aug 2011
    Vancouver, BC
    1998 750iL Individual
    Easier or harder than on the V8, for you guys that have done it?
    Own an E38? Add it to the E38 Registry!
    http://www.e38registry.org/
  9. #34
    Kansas City, MO
    2x01 750, 01 740
    Quote Originally Posted by MrCi View Post
    The V8 doesn't need the Jesus bolt to come off, so automatically easier.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
  1. Turn car off immediately if water pump bearing goes bad.
    By Raudi Driver in forum 1995 - 2001 (E38)
    Last Post: 07-21-2013, 06:14 AM
  2. Water pump bearing failed. Suggestions?
    By Haadkoe in forum 1995 - 2001 (E38)
    Last Post: 07-09-2013, 01:36 AM
  3. water pump bearings
    By 777mech in forum 1976 - 1989 (E24)
    Last Post: 01-31-2012, 06:44 AM
  4. Bad Water Pump Bearings??? Annoying noise
    By bimmerspeed in forum 1996 - 2003 (E39)
    Last Post: 09-17-2010, 03:57 PM
  5. Wobbling Fan / Pulley = Water Pump Bearing?
    By Hess in forum 1991 - 1999 (E36)
    Last Post: 06-06-2007, 03:30 PM
