Anyone happen to know if Macht Schnell 3 point factory belt receptacle mounts (https://www.turnermotorsport.com/p-3...chnell/?pdk=Aw) work with VAC floor mounts for race seats? I see that the Macht Schnell floor mounts are designed for an E46 but can be modified to fit an E36, but I'd rather just buy a floor mount that's made for the E36 (VAC) rather than have to modify it. However, I'd like to keep the factory 3 point belt receptacle so I can continue to use my Schroth quick fit harnesses and occasionally run 3 point belts on the street.
2003.5 BMW M3 Coupe (Daily Driver) | Titanium Silver | Black Nappa Leather | 6MT | Cold Weather Package | Premium Package | Navigation | Harmon Kardon | Matte Black Grills | Dice iPod Integration
1998 M3 Sedan (Track Car) | Estoril Blue on Dove Gray | 5MT | Dinan Cold Air Intake and Stage 2 ECU | Stromung Catback | TC Kline Double Adjustable Coilover Kit | APEX ARC 8 | Dunlop Direzza ZII Star Spec | PFC 08 Brake Pads | Cobra Suzuka GT Seat | Schroth Quick Fit Harnesses | Illuminated ZHP Shift Knob
This is probably what you want instead of those MS brackets:
https://store.vacmotorsports.com/vac...kit-p2303.aspx
And pair it with your choice of matrix style floor mounts (VAC and MotionMotorsports sell them).
I know that the Macht Schnell adapters are specifically marketed as allowing you to mount the factory belt receptacle; the VAC mounts appear to be for harnesses, but have you been able to use those VAC adapters to mount factory belt receptacles?
"yes" i am using a rear all cloth buckle attached to a vac mount to slip in side belt hole of OMP seat.
VAC also sells a factory seat belt kit.
Good to know, thanks! The price of the VAC mounts is much more appealing than the Macht Schnell mounts.
For anyone interested in the update, I was able to successfully retain my stock 3 point seat belt mounting points using the VAC seat belt mounts (sedans need both left and right adapters).
Do you have any photos of the installation ?
www.clubcsl.com - I am a BMW Motorsport fan !
