Page 8 of 78 FirstFirst 1234567891011121314151617183358 ... LastLast
Results 176 to 200 of 1931
Thread: m52 Turbo Build
  1. #176
    Mar 2013
    Upstate NY
    M3
    I'm anxious to find out, my boost controller didn't work so I've just got to use a spring pressure so I won't be able to lower it to experiment. The 257 is rated at 630 HP and flows 62lb so honestly there's no reason mathematically it shouldn't be able to make 520whp.
  2. #177
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by Mklock View Post
    Yeah I think thats a reasonable expectation.
  3. #178
    Virginia
    97' m52 turbo
    All this PSI talk is making me extremely anxious... Spent all weekend in the garage. Probably around 15 hours total, I'm beat.. I'd be lying if I didnt say this project is starting to take a toll on me physically and mentally... Took me a good 5 or so hours to tighten the bolts to the manifold (since the head was already on the car). If anyone is going with the SPA put it on before you install the head if possible and have 3 or more friends help. It was total pita.
    Intercooler mocked up; Either going to have it welded to the bumper brackets or bend steel to bolt it to the bumper bracket bolts. Thanks to Butters for the IC recommendation. Its solid as hell
  4. #179
    Mar 2013
    Upstate NY
    M3
    Badass, can't wait to see another boosted e36
  5. #180
    Virginia
    97' m52 turbo
  6. #181
    Virginia
    97' m52 turbo
    Car is moving right along. Piping was pretty easy, actually. Almost like it was meant to be.
    The only thing that really concerns me is having the scavenge so close to the hot side. I may make a heat shield or wrap it. There is literally no where to put it
  7. #182
    Feb 2012
    1995 BMW M3
    Put your scavenge here. Best place.
  8. #183
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    How do you have it mounted?
  9. #184
    Feb 2012
    1995 BMW M3
  10. #185
    Feb 2012
    1995 BMW M3
  11. #186
    Virginia
    97' m52 turbo
    I never though of that location. Looks a lot better than where I have it. Thanks again Raj
  12. #187
    Jun 2003
    Cape Cod, MA
    95 M3
    Where did you get the intercooler kit from? 2.5'' piping?
  13. #188
    Virginia
    97' m52 turbo
    Quote Originally Posted by AntiHero View Post
    2.5" from Turbo
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    3" to intake manifold
    http://www.ebay.com/itm/351193523274...%3AMEBIDX%3AIT
    2.5" to 3" silicone elbow - This is only if your IC has 3" inlet.
    Reciprocating saw with these https://www.zoro.com/dewalt-reciproc...VbkaAuaO8P8HAQ works great for cutting.
    You really don't need all of the bends though, I have a ton of extra piping that I'll probably never use.
  14. #189
    Virginia
    97' m52 turbo
    Ill sell you the pieces that you need
  15. #190
    Jun 2003
    Cape Cod, MA
    95 M3
    That could be an option.
  16. #191
    Virginia
    97' m52 turbo
    What are good options for atmospheric blow off valves?
  17. #192
    Mar 2013
    Upstate NY
    M3
    EBay is your friend I went with the seller named wyntom his bov works great for 40$
  18. #193
    Apr 2006
    Minnesota eh?
    86 325es
    https://www.racepartsolutions.com/it...?category=9281
    this is what I have. No leaks at 35 psi when I leak tested. You can buy ones on ebay that look identical for $40
  19. #194
    Virginia
    97' m52 turbo
    How does it sound?
    I had wishful thinking when I order this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Definitely is too big. Almost got it to fit though.
  20. #195
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by 328iFun View Post
    How does it sound?
    Braaaaaaappppppp
    Psssssssshhhhhh.
  21. #196
    Mar 2013
    Upstate NY
    M3
    Go to your air hose and disconnect the main line off the compressor and it sounds just like that.
  22. #197
    Virginia
    97' m52 turbo
    Ok
  23. #198
    Apr 2006
    Minnesota eh?
    86 325es
    Its pretty quiet. Not like the stupid look at me whistling ones that the subaru people all have.
  24. #199
    Virginia
    97' m52 turbo
    So I got the car running as it should be. Idling fine. Waiting for funds to buy a injectors/maf/tune at this point. Clutch engages great, no water in coolant/ vice versa. Turbo sounds absolutely addicting.
    I've read mixed reviews on RKtunes anyone here dealt with him? I would like for the tuning process to go as smoothly as possible.
  25. #200
    Mar 2013
    Upstate NY
    M3
    Buy rajis trm tune, that's what I use and you wouldn't know it's turboed unless I throttle it that's how good it runs.
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
