Page 75 of 78 FirstFirst ... 25506566676869707172737475767778 LastLast
Results 1,851 to 1,875 of 1931
Thread: m52 Turbo Build
  1. #1851
    Jan 2017
    RI
    1994 325is
    Quote Originally Posted by 328iFun View Post
    Lol, maybe.
    I knew someone that had one awhile back, the amount of crap she could fit in was mind boggling. Considering how tiny they are
    Sent from my SM-G960U using Tapatalk
    I have looked at them for a daily that exact reason. Good mileage and can fit my surfboards and other crap.
  2. #1852
    Virginia
    97' m52 turbo
    Have only heard good things about them.
    And they can be had as a standard as well.
    Speaking of surfboards, I'm off to my hometown, obx nc tomorrow. Getting married on the beach on Sunday... we waited 16 years!
  3. #1853
    Sep 2017
    Netherlands
    e36 328i turbo
    Congrats man!
    hope you have/had a nice wedding+honeymoon!
  4. #1854
    Virginia
    97' m52 turbo
    At what point do you know your ZF is dead or just about dead?
    I've replaced Master/Slave cylinder thoroughly bled the hydraulic system because I couldn't get the car to go into gear.
    Pumped the clutch for about 1 hour, got pressure back. Car was shifting okay, had to slam it into gear, popped out of 3rd at one point.
    Now the car won't shift into gear at all
  5. #1855
    Vancouver, B.C., Canada
    '97 M3
    Hydraulic issue then bent shift forks trying to shift?
    It would have been best to pressure bleed the clutch from the slave cylinder up. They can be a bitch trying to gravity bleed them.
  6. #1856
    Virginia
    97' m52 turbo
    Possibly...
    I spent a good 4 hours make sure the thing was bled a few weeks ago (Brakes and Clutch) and then when I replaced the clutch pedal yesterday another 2 hours or so. Took another hour of pumping the clutch pedal to to regain pressure.
    Used a vacuum bleeder and reverse bled the slave/calipers. Replacing the master cylinder is probably one of the irritating tasks so far
    Drove the car, it shifted but still required a bit more force than usual. Probably wasn't a good idea to redline 1st and 2nd as soon as I got on pavement... Couldn't get the car into third under load, had to slow down.
    I'm going to go with shift forks or that the trans is going to need pulled and inspected. Guess I'm looking for a replacement ZF as well
    Side Note, Kill Story
    A few weeks back I had modified newer style 350z pull up beside me at a roll, about 25 mph. He wanted to race, I was in third, he started to pull a way a little so I dropped into 2nd and hit about 6800rpm. By the time I found the middle of the power band in third gear I had at least 1 1/2 to 2 car lengths on him and pulled away. We slowed down and he gave me a thumbs up. This was the first person that actually pulled up next me though. I figure that car was making about 320whp? So the E36 has to be right around there...
  7. #1857
    Virginia
    97' m52 turbo
    Went back out to the garage and checked everything over again...
    Checked the bleeder to the slave cylinder appeared to be a little loose. So I tightened it, pumped the clutch a few times and was able to put the car into gear and shift fine.
    I then started to back out of the garage while depressing the brake and as soon as I came to level ground I couldn't shift into gear, once again. Was able to start the car in gear and get it back into the garage
    I don't think the shift forks are bad... Not sure whats going on with the hydraulics? I decided to bleed everything again, fluid ran out with no bubbles, all bleeder valves.
    I just finished pumping the clutch for 30 minutes but got tired of it
    Suggestions? I have no idea whats going on with this thing
  8. #1858
    Virginia
    97' m52 turbo
    Got it to go into gear... Notchy as hell but is at least drive-able now
    Must be shift detent pins
  9. #1859
    Virginia
    97' m52 turbo
    Hey everyone, been awhile since I've been on here.
    I'm starting a new job in a few weeks with a long drive, so I've been toying around with the idea of swapping my turbo setup into something a bit more comfortable. Preferably a Sedan. I want the drive to be as fun and comfortable as possible
    I can't seem to find any clean shells at all but have found an auto that's immaculate for a good price. How long will an auto hold up if I'm easy on if I just swap the engine? That way my wife can drive it too, I don't want to spend the coin on a trans swap right now, maybe later
    ideas/suggestions?
    Thanks again
  10. #1860
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Auto might last a little while at 5 psi. But it’s 20-25 years old.
  11. #1861
    Virginia
    97' m52 turbo
    Im tempted to try it and throw ZF in when it dies
  12. #1862
    Mar 2013
    Upstate NY
    M3
    Just buy a daily, I daily a E46 sedan, it's awesome and a *little* peppy if I wail on it. E46 are dime a dozen and almost identical to the E36.
    If it means anthing I average 25mpg.
  13. #1863
    NY
    skateboard
    Quote Originally Posted by Mklock View Post
    Except their rear subframe/trunk floors were made out of compressed cardboard lol
    ― George Orwell
  14. #1864
    Virginia
    97' m52 turbo
    Thanks Guys,
    I'm looking at this: https://richmond.craigslist.org/ctd/...087502283.html
    Mk, I think I'm done with the convertible - I sold the hardtop and a few other items off of it yesterday. My drive is going to be quite a ways away. I have a VW, a Bike, and my truck. But I think having a clean nice boosted E36 would awesome to drive 2 days out of the week to mix it up. Would also be more appealing to a buyer if I wanted to sell it one day.
    The car above is a 4 door, super clean inside and out - only downfall is that its not (M3, ofoucrse) a manual. Swapping from auto to manual a pain? I have all the parts from the vert.
    Let me know what you all think.
  15. #1865
    NY
    skateboard
    Looks like a great daily to me
    ― George Orwell
  16. #1866
    Virginia
    97' m52 turbo
    Quote Originally Posted by GG///M3 View Post
    Price?
  17. #1867
    NY
    skateboard
    Offer him 2k
    ― George Orwell
  18. #1868
    Mar 2013
    Upstate NY
    M3
    Lowball him, old car will need ton of work. Also, I guess they do have subframe issues (e46) but honestly I've had 3 and all automatics have not had subframe issues. The manuals get hot dogges but still, they shouldnt crack like they do.
  19. #1869
    Sep 2017
    Netherlands
    e36 328i turbo
    Do it, just put in your M52 with the manual, lots more fun. if you will do the transplant from the vert I don't really see why you won't just throw the manual in as well.
    ohw, don't go e46, I had a 330ci, and that compared to my (previous non boosted) e36 was a big let down.
    It is a better car overall, but lacks character imho.
    The e36 in the advert looks nice, but with that mileage it probably needs new front lower control arms a.o.
    No biggie, but something to keep in mind.
  20. #1870
    Virginia
    97' m52 turbo
    The turbo setup is definitely going into a clean chassis. Just having trouble finding one... especially manual.
    Found another auto, silver, pretty decent but has 3.91 diff, so thatd have to be changed out as well.
    Ideally, I like this car but the price is just too high. Has the 3.15 diff and appears to have a ton of upgrades a f fixes and I think looks pretty darn good. But hes asking 5k without the wheels, smh:
    https://www.facebook.com/marketplace...7078202976153/
  21. #1871
    Sep 2017
    Netherlands
    e36 328i turbo
    looks solid and complete for the 5K. begs to be un-stanced IMO, but it is a nice car. good colour too.
  22. #1872
    Nov 2016
    Long Island, NY
    A few
    IMO it's better to spend more up front and have a good solid base. The E36 isn't getting any younger...
  23. #1873
    Virginia
    97' m52 turbo
    I agree ^
    Just a lot of coin though... I'd imagine with my turbo setup in it that it would be worth in upwards of 10k, so kind of an investment
  24. #1874
    Jun 2005
    New England
    Maybe you could eventually build an auto. The ones most people do are 3 speed and they change to a manual
    Valve body but perhaps auto could be kept. 3 speed is not efficient. No one has fitted an OD yet. They are bigger. Also I think they all need to be built to take the torque.
  25. #1875
    Virginia
    97' m52 turbo
    I got him down to $1800... Not sure about it though
    Offer him 2k
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
