Page 70 of 71 FirstFirst ... 2045606162636465666768697071 LastLast
Results 1,726 to 1,750 of 1763
Thread: m52 Turbo Build
  1. #1726
    Apr 2006
    Minnesota eh?
    86 325es
    where is your snow lol
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  2. #1727
    Sep 2017
    Netherlands
    e36 328i turbo
    thing sounds awesome!
    you have your EBC set to 9, and you reach 12?
    so, you experience some boost creep I think.
    Do you use the SPA wastegate piping with a 38mm?
  3. #1728
    Virginia
    97' m52 turbo
    It was 18 degrees this morning, the turbo was screaming... I work with guy who lives on my road and the other day he was like:
    "Do you drive green BMW, turbocharged? And I was like maybe, why? (I automatically knew he was going to have a noise complaint). That thing sounds like F1 when your going up the hill near my house, I was outside and was like good god".
    But anyway, although I like the cold weather for the cars sake, I'm hoping the Snow holds off as I have a few side jobs this weekend... Last time I checked we're supposed to get 5 inches or so... Not to bad
  4. #1729
    Virginia
    97' m52 turbo
    Quote Originally Posted by et89 View Post
    Thanks, I did the exhaust differently than what you typically see on here. I got tired of trying to fit a 3" DP" so I made 2.5" DP that I welded directly to a gutted catalytic converter (which is about 4" diameter internally). Right after the converter is a Y Pipe, single 2.5" inlet to dual 2.5" outlets. I then ran (2) 2.5" pipes to the rear of the car. One pipe is muffled with a flow master (I think) and the other is open. So the turbo spools great and the car has a pretty cool sound. Wastegate is also open
    Overboost was set to kick on at 8 PSI in the video but peak boost hit 10. With overboost set to 7 I can hit 14 PSI at wide open throttle due to back pressure. Turbo hot side is a .58, low-mid range power is great. If I don't dog the car boost control works great
    SPA dump tube to 38MM Turbo Smart Ultra Gate 7 psi spring currently
    Zack and I think the car is at the perfect power level
  5. #1730
    Dec 2016
    Los Angeles, California
    2002 E46 BMW 325i
    Is ATPTurbo a good brand to get oil supply lines from? Or is there a better source? I would like to get most oil related things from rallyroad but if they don't have it I'll need an alternative
  6. #1731
    Virginia
    97' m52 turbo
    Quote Originally Posted by armenh7 View Post
    Just make your own:
    -4 AN PTFE Steel Hose, 1/8th to - 4 AN earls straight fitting (for turbo), and then 2 90 degree -4 an hose-end fittings.
    If your going rally road and want to run an easy oil pressure gauge in addition to tapping the vanos for feed, use this:
    https://rallyroad.net/products/oil-g...ribution-block
    Here's the significant others first time driving the E36... She hates it but loves it
  7. #1732
    Dec 2016
    2002 E46 BMW 325i
    Quote Originally Posted by 328iFun View Post
    Just make your own:
    I've seen the oil distribution block, thank you though
    What do you think about these?
    https://www.pegasusautoracing.com/pr...p?Product=3480
    https://www.summitracing.com/parts/f...4-bl/overview/ x2
    https://www.speedwaymotors.com/Earls...er,146841.html
  8. #1733
    Virginia
    97' m52 turbo
    Those will work
  9. #1734
    Dec 2016
    2002 E46 BMW 325i
    Those will work
    Great. I'll teach myself how to make the fittings and whatnot. I have my manifold and turbo but haven't mocked anything up. I can't decide between getting oil from the VANOS banjo bolt (https://rallyroad.net/products/vanos...lsupplyfitting) or oil filter pressure sensor (https://rallyroad.net/products/oilfeedadapterblock). I think I'm going to go with the VANOS one because it requires less hose and it'll look cleaner
    Will I need an oil restrictor since I'm using a journal bearing turbo? I've been trying to do some research on it but most stuff is for ball bearing turbos which do need it. I'm thinking -4AN feed and -12AN draining back to the oil pan bolt
  10. #1735
    Sep 2017
    Netherlands
    e36 328i turbo
    Sounds like an interesting setup
    But also in the video you uploaded today, It sounds really good!
    I'm re-doing my exhaust to a Full 3 inch form a 2,5inc now, I needed to go at the passenger side footwell with a hammer to get it done.
    My GT28 was simply to small and couldn't get my boost under control.
    going for an HX35 on an SPA manifold, with 44,5mm wastegate piping to a 45mm turbosmart.
    going to port the hole in the SPA to 40mm, and hopefully that way I will be able to control my boost well enough.
    comparing it to your setup: I should do just fine. only I am recirculating, so fingers crossed.
    on a sidenote, any Idea what the pressure in the lower Vanos oil feed line is?
  11. #1736
    Virginia
    97' m52 turbo
    How far off are you on your target boost? Spiking that bad? What about WOT?
    The pressure varies of course, higher when cold, lower when warm.
    Typically sits around 20 psi at idle when warm. 60 cold idle, 70-80 under load cold. 58-60 warm under load
    Oil pressure needle is usually symmetrical with RPM and pretty spot on, as expected
    Thats really up to you and your setup. If your bottom or top mount. Better to get a foot or two more just to be on the safe side. But that PTFE stuff is expensive too
  12. #1737
    Sep 2017
    Netherlands
    e36 328i turbo
    yes, pretty far of. with my internally gated GT28, 4psi waste gate spring, i had peakes of 18psi down low with my EBC (innovate SCG) set to 100% WG duty, theoratically target boost was 11psi.
    this happened really low, and i fixed it with using a mechanical boost controller set to 12psi parrellel to the EBC.
    Boost tappered down after 5k RPM to 8psi, all the way down to 6psi at 6,8k RPM.
    lots of torque down low, no power up top due to back pressure. setup was build by mosselman for ~6psi.
    I spent to much time here, and because of all the forced induction build threads, even 14psi sounds like baby boost now
    It was rubbish because i wanted to much.
    My friend who owns a S2000 said it didn't feel any faster than his honda.
    that was it, time for a change
    The 4G36T, SR20 and others that i have read about using Holsets have problems with the oil return not being big enough.
    but those guys see 100psi at WOT where they get their oil feed from. thanks for the info!
  13. #1738
    Virginia
    97' m52 turbo
    Wow, that's some serious spikage
    No prob
    Sent from my SM-G960U using Tapatalk
  14. #1739
    Virginia
    97' m52 turbo
  15. #1740
    Vancouver, B.C., Canada
    '97 M3
    Like a Kohler S265
    A Kohler with a BW s265? I think you mean BW s256, either way, thatís baller!
  16. #1741
    Virginia
    97' m52 turbo
    Quote Originally Posted by chikinhed View Post
    Your right...
    Log splitter, got left out in the rain. Now it wont start. Replaced carb, found rust in the bowl of the original carb. Fresh gas, tried starting on carb cleaner, nothing. Swapped plugs, etc... tried all the basic stuff. Bypassed on/off switch. All I get is backfire.
    Bad timing, about to get some snow here too. Power usually goes out!
  17. #1742
    Apr 2006
    Minnesota eh?
    86 325es
    Do you get spark if you take the plug out and hold it up against the cylinder head?
  18. #1743
    Virginia
    97' m52 turbo
    Yes
  19. #1744
    Virginia
    97' m52 turbo
  20. #1745
    Virginia
    97' m52 turbo
    This log splitter always works, unfortunately
  21. #1746
    Apr 2006
    Minnesota eh?
    86 325es
    Shut the fuel off to the carb and see if it will fire on starter fluid?
  22. #1747
    Sep 2017
    Netherlands
    e36 328i turbo
    Wear a flanel shirt and go at it,
    A little roleplay goes a long way
  23. #1748
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    This.
    Also, check the bowl screw/bolt on the bottom of the float bowl. If itís screwed in too tight, gas wonít flow up into the main jet.
    Took my pressure washer carb (tecumseh engine) apart last year to clean it, and I couldnít figure out why it wouldnít run for shit after a few shots of carb cleaner. Turned out to be the bolt at the bottom. Small engines are awesome when they work right, but a pain when they donít.
  24. #1749
    Nov 2013
    VA
    trbo 96 328;98 m3
    Car sounds great! Once it gets warm it'd be nice to see your setup in person. Hope all is well
    96 328 Turbo
    98 M3/4/5
  25. #1750
    Virginia
    97' m52 turbo
    Quote Originally Posted by bmw328m52 View Post
    Thanks,
    Sounds like a plan!
    We we're talking about boost creep earlier, I recorded a video of what was I talking about with my car; Third gear WOT, hits 14(13.5) PSI with boost controller set to 8
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 10:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 11:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 03:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 04:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 12:17 PM
