Guys, question:
I have a second AEM Meth Nozzle sitting in my garage with no use... Was thinking about connecting it somewhere in the turbo intake to help cool it down. I already have 1 nozzle in the intake boot but was thinking having a second one installed would help cool the turbo.
My question is where should the nozzle be placed for best effect? Weld a bung in the piping close to turbo, in the middle of the air filter, or right after the air filter?
or use another one of these in my silicone bend:
Pretty sure I had a bit too much fun today with a buddy... Burnouts and what not.
75% positive my clutch is gone at about 3k+ miles, gripforce stage 3.
Car wont move, had to get a tow home. Guess I'll be pulling the trans and investigating :-(
If it is the clutch, what do you guys recommend for a replacement ?
Little update for everyone,
Went ahead and ordered and installed a lift, makes life SOOO much easier. I recommend MaxJax by Danmar; Good quality and even better customer service. Had the clutch removed in about 45 minutes or so.
Should I be good reusing my flywheel and pressure plate? Clutch is toast, pics below
Gripforce Stage 3 didn't hold up too well. Lasted me maybe 2,000 miles or so
Sent from my SM-G960U using Tapatalk
If you put another ceramic puck disc in it will probably bed and work again for awhile, but any other friction material is going to die a fast death riding on those two. Mabey try a clutchnet disc.
went ahead an ordered another ceramic clutch kit
It is a struggle to get 6 puck discs to last more than 15k miles in any car. They require you to slip it so much to leave smoothly without chatter, and then they don't have much wear material vs a solid disc.
It looks like one of your pucks disintegrated causing the premature failure.
15k isn't much. But isnt terrible as long as the fw and pressure plate remain good... not in my case though
Mine was a result of several, and I mean several long burnouts one after another. Car wouldn't even move afterwords... I had fun so it's all good.
Thinking about signing up for some technical driving courses nearby. There's no where around my area where I can and really get a feel for the car
A normal stock organic clutch works by creating an adhesion between the disc and friction surface just like a brake pad. It doposites a polymer film onto the flywheel surface which sticks to itself. Everything in the disc is softer than the flywheel so the friction surface doesn’t wear out, the disc does. A ceramic disc is much harder than the iron flywheel and pressure plate and it makes its friction by actually digging into the friction surface like tire studs on ice. It’s the equivalent of using a grinding wheel as a clutch disc. With a ceramic clutch the flywheel, pressure plate, and disc are all consumbles. Your new pressure plate and flywheel you ordered will also be going in the garbage in a year or two.
Ordered this setup this go around.
Was stage 3 previously, says this one is stage 4 but looks the same as the 3 to me?
Not sure what would make it a 4
Looks to be an unsprung clutch disc. Would not recommend, as that will put significantly more shock load on the drivetrain. You'll start breaking trannys namely, with maybe a driveshaft or axle too. That's pretty much the only difference between most of the ebay stage 3 and 4 kits. Spring vs unsprung. Sent from my Pixel 2 XL using Tapatalk
Ready see how this unsprung clutch feels...
Got the car reassembled and just took her out. Felt great to drive it again, was sitting for about 3 months.
How many miles do you all recommend for 'breaking-in' a ceramic clutch? There was no recommendation in the directions
1989 535i - sold
1999 M3 Tiag/Dove - sold
Yeah...
I cant handle babying it much longer. Made it about 30 miles so far
Could help my self......
F-it...!
