Page 66 of 78 FirstFirst ... 1641565758596061626364656667686970717273747576 ... LastLast
Results 1,626 to 1,650 of 1931
Thread: m52 Turbo Build
  1. #1626
    Jan 2017
    RI
    1994 325is
    Glad it is running well!
    Sent from my SM-G930V using Tapatalk
  2. #1627
    Virginia
    97' m52 turbo
    Only problem now is
    Low pipe
    Sent from my SM-G960U using Tapatalk
  3. #1628
    Jan 2017
    RI
    1994 325is
    Is that your intercooler piping? You went below subframe right?
  4. #1629
    Virginia
    97' m52 turbo
    Yes below subframe...
  5. #1630
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Looks too low. Should be able to get it higher with better routing and clocking.
  6. #1631
    Virginia
    97' m52 turbo
    I did have it higher at one point. With the silicone boot on turbo outlet pushed all the way up. Maybe if I cut the boot a bit. But it can really only go so higher before it hits the swap bar. Car is lowered on Koni + H/R springs so that doesn't help either
  7. #1632
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    Listen to Phil. You can get that way higher.
    Keep the pipe to the inside of the inner balljoint and the outside of the of the sway bar mount. You'll probably need a slight horizontal bend.
  8. #1633
    Virginia
    97' m52 turbo
    That looks pretty perfect. Thanks for the pics thats what i'll try to replicate
  9. #1634
    Jun 2004
    The D, MI
    Each of the three sections is a step up in piping size too. Not some weird optical illusion. 2.5" from the turbo-> 2.75"-> 3"
  10. #1635
    Virginia
    97' m52 turbo
    I was wondering about that.
    Looks great. Gj
    I might use some mild steel exhaust piping I have lying around. Be a bit more durable
  11. #1636
    Virginia
    97' m52 turbo
    Think this will work much better
  12. #1637
    Jun 2005
    New England
    That hot side pipe looks better. A welded joint rather than a clamped silicon one would be a little higher. The silicon elbow at the turbo and coupler at the IC would still give play in the event of contact.
  13. #1638
    Virginia
    97' m52 turbo
    I was thinking about welding it myself... it would probably leak under pressure though.
    Suppose I could try
  14. #1639
    Jun 2005
    New England
    Test it by capping the ends and pressurizing it. Or put an led light in it at the weld and look for the pinholes and weld over.
  15. #1640
    Virginia
    97' m52 turbo
    Hoping to finish exhaust today
  16. #1641
    Virginia
    97' m52 turbo
  17. #1642
    Virginia
    97' m52 turbo
    Anytime I drive this car and put miles on it I feel that I need to thank everyone here, so:
    Again, shout out to all the fine folks here that helped me push through (and to continue to push me through) this endeavor.
    Here's a pic of my car next to a clean e30 I found in town today (not boosted though).... I could take it... lol... no seriously, I would take it.
    You guys freaking rock!
  18. #1643
    Mar 2012
    Renton, Wa
    98 m3
    Thank you for keeping life in bfcfi!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  19. #1644
    Virginia
    97' m52 turbo
    Quote Originally Posted by vollosso View Post
    bimmerforums built 328i m52b28 6262 turbo
    edited 4/14/2018
    bfcfi forever....
    Butters Stoch
    someguy2800
    Pbonsalb
    chikinhed
    Vollosso, Vollosso (twice for dealing with my stupidness :-))
    Kevin325i
    zJACKRABBIT
    fltecher0680
    rajicase (for his smartassness)
    mklock
    Antihero
    Notorious VR
    e36 328is
    e36Mylo
    AntiHero
    bmw328m52
    Thompson501
    young bryce (whats his name?)
    Keeping thinking of new people everytime I re-read.
    thread is too long, if I missed anyone, let me know. I can't read through it all...
  20. #1645
    Nov 2013
    VA
    E36
    Bfcfi will always be my first source for guidance, never facebook. Thanks for the help last week though. Even after three years of boosting, I am still learning.
  21. #1646
    Apr 2017
    Florida
    E36
    Whats up? How’s your build doing?
  22. #1647
    Virginia
    97' m52 turbo
    Good. Been driving a lot, doing burnouts and what not
    What about you T Bone?
  23. #1648
    Mar 2013
    Upstate NY
    M3
    Omg, made a list! I feel special
    Yes burnouts are fun, make sure you're using cheap tires.
  24. #1649
    Apr 2017
    Florida
    E36
    Hopeful to have the car back next week.
    cage almost finished, splitter, wing
    still need to drop ride height 2 inches
    plan on only tracking. I enjoy the road coarse more than ever.
    hopeful to be competing this year
  25. #1650
    Virginia
    97' m52 turbo
    Quote Originally Posted by Mklock View Post
    Plenty of cheap tires. Old wheels I've acquired throughout the years
    Took a few friends for a drive during the weekend and they loved it
    Quote Originally Posted by Thompson501 View Post
    Wow, looks like your making a legit track car.
    looks great
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
