I think he was right about the ICV awhile back though:
I unplugged that mfer and no more f'd up idle. amazing
-------------------------------------------------------------------------------------------------------------------- Bry195:
As easy as it is to start the car and unplug the electrical connector on the IACV i would have thought you woul have done it even if its to tell me im crazy. But here goes I'll explain
even with a good iacv the idle can hunt. The OEM or even tuned IACV is has a mathematical model that tells it how much to open and close over a given amount of time based on the physics of the motor the model was tuned or developed for. Part of this model is to uses rpm feedback and other parameters to land the comanded value smoothly on the actual value with an expectancy window that we tell it to try again if it (mid move) is not where its suposed to be.
so imagine that one of the variables that provides feedback to the math model is a little off. It cold undershoot the target or overshoot the target. So the expectancy window throws it in the opposite direction. 1 of 3 things happen. On reveral it overshoots another window and throws yet another reveral at it. So it either drifts into the right window, drifts by the window, or hits the target.
so you get a decaying oscilation an increasing oscilation a steady oscilation or you hit it on the head.
if you unplug you get nothing but it eliminates the timing, fuel, and iacv compensations. If the car dies when you unplug you get to open the throttle plate idle adjust and tke a bunch of crap for touching the untouchable.
you adjust it to where the car jst stays running and decide you dont need the iacv. Or you decide im going to open it up further while the car is running and all holy hell braks loose with mixtures and rpm and then you unlug and call it good enough. Or you push through the storm and keep opening the idle adjustment and remember some smat a** was whining you forced him to write a book for an experiment that is just as likely not the same as his problem was s it is that al the same indicators led him to solve his problem this way. Touch the untouchable but only half of the tuning tables are going to work when you have the CEL. My rpm oscillation had 1 second the .5 second then .25 second intervals and then dead silence when the CEL was not on and the PID loops for fuel, IACV, and ignition stayed in 1 table and fell into the expectancy window.
the iacv retards and advances idle speed. Its a very fast continuously varable bi directional valve that is corrected by several other tables that lag the valve......thus the need for the math model to begin with.
Friction, inertia, temperature, afr, .......the model compensates for a limited amount of variation.
Well,
If I'm going to make 20-22 PSI on stock b28 then you should atleast be making 30-33 on your built motor. Just sayin'
Only one way to find out.
I ran a 300k m52 to 24# on 93 no meth with a 35r and trapped just about 130mph on a Technica tune.
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
That's impressive
I plan on doing some major wiring this weekend. That computer I was talking about I plan on getting it all setup and the Meth Kit as well.
Also want tap the OEM harness to the ZT-2 so I can log properly. I know you've you done it and I've read you can tap the diag port under the hood for some of it
Yeah your tune has fuel for it.
If you have enough octane is the real question.
Your biggest problem is that little hotside.
1989 535i - sold
1999 M3 Tiag/Dove - sold
I can't say for sure, but on 92 I wouldn't wanna go much past 14-15psi. With meth you can probably get by with a bit more, but those stock rods won't like a lot more i don't think.
Sent from my SM-G900V using Tapatalk
That's assuming 9.0:1 compression.
sounds good, I don't wanna chance the car for summer time, just wanna enjoy it, 14 PSI max then and with meth, ill push it when the block is done. 14 should be enough to break some hearts on the freeway. I have full intentions to build that block, if my season goes well and let her rip 20+ with a better clutch too....
yes 9:0:1
If I'm enjoying 7-10 PSI on a b28 with a 6262, .58 AR - I'd say your going to love it as well - especially with your additional displacement.
Most I've done is like 12.6# and the car flys. Granted, its not a drag monster like a few of the guys on here but makes a fast reliable street car.
Turning it up is just being trivial in my opinion - If I didn't have the EBC I would happy with 7-10# quite awhile.
Get your car done, start with 7 if everything checks out turn it up to 10. I think 10# would be solid for you
just my .02
What back housing do you recommend?
Meth Heads, do you guys think this will spray correctly. Its for the snow nozzle so I had to thread the AEM nozzle in the opposite direction. Also the nut will have to go into the boot which is concerning in the event it were to fall off. Thoughts?
Put it on the silicone then cut the excess away.
1996 332IS
Built 3.2
I ran that exact fitting a while ago. It will be fine.
1996 332IS
Built 3.2
Cool deal
Received LCD head unit and a few parts for my incar mini itx pc build, so I can run digital dashboards and diganostics via scantool XL professional:
Here are few dashes (if only you could read oil pres / temp from the OBD II port)
The obd2 port kinda sucks tho for sample/refresh rate. Definitely not close to real time unfortunately.
1996 332IS
Built 3.2
Yeah, unfortunately.
I think there's like 2-2.5 (sometimes 3) second lag. Gauges are just a plus will be cool to have on when a friend or family member is in the car.
Rigging it up more so for:
- Diagnostics
- ZT-2 Data Logging
- Tuner access at anytime
- Media
Possibilities are endless with a Computer... So much third party software out there
It'll be cool.
Could be good for "ethical" hacking too... Could throw kali linux on there (if anyone knows what that is) and have a lil fun
I wonder there's a way to speed up the sampling rate...
1989 535i - sold
How do you plan to mount the head unit? In the radio slot? Or sunglass holder? I've debated this forever
Sent from my SM-G930P using Tapatalk
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
