Page 62 of 78 FirstFirst ... 1237525354555657585960616263646566676869707172 ... LastLast
Results 1,526 to 1,550 of 1931
Thread: m52 Turbo Build
  1. #1526
    Manchester, N.H.
    96 332IS 6466 turbo
    Yes, buy 3-5 gallons of VP M1 methanol. Then cut it yourself.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #1527
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Butterz do we cut it in a 50/50 ratio with distilled water??
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  3. #1528
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by JPE36M3 View Post
    Yes but by weight not volume. So just mix it 70/30 heavy on the meth. Or 60/40 whatever.
    1996 332IS
    Built 3.2
  4. #1529
    Virginia
    97' m52 turbo
    Looking forward to running the meth.
    I bought a flip down LCD head unit that has AV inputs. I plan to build a custom Mini ITX PC for data logging and digital gauges with an in car UPS. Tuner will able to remote in at anytime and make adjustments
    I was reading Intake Temperatures the other night 46f ambient, Intake was about 86f. Be interesting to see the difference with Meth
  5. #1530
    Manchester, N.H.
    96 332IS 6466 turbo
    Your turning into a toned down mild bry195.
    1996 332IS
    Built 3.2
  6. #1531
    Manchester, N.H.
    96 332IS 6466 turbo
    Now that your going to become a meth head junkie. Let me fill you in on a little secret.
    Buy a second tank, pick up a 3 way solenoid from eBay so you can toggle between tanks. Fill the second tank with 75/25 antifreeze/ water. Obviously heavy on the water. Then if you are getting chased by the police, flip the switch and you will have a James bond smoke screen. Bam.
    1996 332IS
    Built 3.2
  7. #1532
    Virginia
    97' m52 turbo
    That is the best idea yet.
    I think I may have to do this asap
  8. #1533
    Virginia
    97' m52 turbo
    What WG spring do you guys recommend?
  9. #1534
    Virginia
    97' m52 turbo
    Dang no one on the spring...
    Drove the car again today after installing new manifold I tapped. No more vacc/ boost leaks
    9 psi @ 11.8 AFR
    No addtl oil at hg seam. And I think it was running down from the valve cover gasket anyway.
    So a good day here in va. Good running car with 60 degree weather
    Cut fenders. Waiting for flares: nice not to rub
  10. #1535
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    nice job on the Taps, did you thread them with an 1/8" NPT? or just push hard and self tap? (I used a tap, not sure the outcome yet on leaks going to test Thursday)
    what flares did you get? im soon realizing the magnitude of my paint Delma and might as well do them... looking for a not so aggressive look
    Quote Originally Posted by 328iFun View Post
    9 psi @ 11.8 AFR
  11. #1536
    Virginia
    97' m52 turbo
    I used 1/4 fittings with 1/4 -18 tap.
    I tried hard tapping the last time... don't do it
    I have felony form reps on the front and ores these for the rear. But comes with fronts that I'm not gonna use.
    https://rover.ebay.com/rover/0/0/0?m...2F253310140419
  12. #1537
    Virginia
    97' m52 turbo
    Integrated my zeitronix zt 2 display into cluster. Has 4 viewable readings on it
    Afr
    Egr
    Lamba
    And 1 user input of choice.. boost etc...
    Took quite a bit of trimming but I'm liking it
  13. #1538
    Jan 2018
    Arizona
    93 325is
    Afr
    Egr
    Lamba
    That's awesome
    Sent from my SM-G935V using Tapatalk
  14. #1539
    Virginia
    97' m52 turbo
    ^ video of it booting up
  15. #1540
    Boston, MA
    E36 M3 Turbo
    Get a spring that matches the lowest boost you'll ever want to run, and you can typically double the pressure amount with a boost controller. I'd say anywhere from 10-15psi spring is a solid middle ground.
    That cluster setup is sweet
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  16. #1541
    Virginia
    97' m52 turbo
    18 psi spring then I can run up to 36
    Korrect?
  17. #1542
    Jan 2018
    Arizona
    93 325is
    Fax all the boots
  18. #1543
    Boston, MA
    E36 M3 Turbo
    This ^
  19. #1544
    Virginia
    97' m52 turbo
    How do you mean?
    Need MilKt to decode
  20. #1545
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    20psi is a reasonable low boost setting. Anything less might as well be NA
  21. #1546
    Virginia
    97' m52 turbo
    Where zack?
    Hey Zack, can we 20 PSI + Meth?
  22. #1547
    Virginia
    97' m52 turbo
    Maximum Boost, Corky Bell -
    Considers that high boost? Am I missing something here? What book are you reading Raj?
    Got home from work today saw the car sitting in the garage, even with cut fenders and not fully complete (to my liking) I have to drive it up and down the road when I get home from work. So much enjoyment
    Thanks again everyone!
    Ps. Thing does a nastay brun out
  23. #1548
    Feb 2012
    1995 BMW M3
    My pile never sees less than 23-24psi any more. "Low boost" is for the birds.
  24. #1549
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    You think the b28 would like 20 PSI?
    Is anyone here running 20 PSI on stock b28 daily? Pump gas?
  25. #1550
    Feb 2012
    1995 BMW M3
    Probably not. That's why you MAKE IT LIKE IT.
    Beat it into submission.
    NO MERCY.
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
