1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Its not too bad. I can knock out a whole rearend in like 1 beer and back in with another...
1989 535i - sold
1999 M3 Tiag/Dove - sold
It's six (6) trailing arm bolts,
four (4) or six (6) driveshaft bolts
and four (4) subframe bolts.
1989 535i - sold
Since he included the trailing arms he may be including the whole rear end, including half shafts meaning leaving the diff in place and dropping the whole assembly. You can unbolt the metal brake line and hang the calipers without disconnecting the lines. The e-brake lines can be disconnected under the hand brake and pulled out but up here in NH they may be rusted and benefit from replacement. It's heavy but if you have a lift that is less of a problem. If I was solo on my back, I'd at least pull the diff first and maybe take more things off the subframe, but it is easier to change control arm bushings with the greater access you have when the whole assembly is on the floor -- especially if you are in a region where cars rust.
Wow,
This sounds like its gonna suck pretty badly.
It may be rusted. I drove the on car on the east coast for a while
Anyone heard of or tried these coil overs?
http://speed-daddy.com/j2-sports-32-...bmw-e36-325-m3
Come do it for me
Two votes for konis.
1989 535i - sold
Those coilovers are way too expensive for cheap coilovers. I have two pair of the "Maxspeedingrods" brand coilovers that are probably the same as those other than paint, and the "24-way adjustable set" was right around $300 shipped I think. They have been great by the way.
And before everyone jumps to conclusions, I've had plenty of Konis and revalved Konis over the years in different setups that I've won regional autocross championships on, in a very competitive class. These cheap crap china coilovers just are WAAAY better than they should be for the money. The only problem with them is that the rear springs are too soft. I slapped in some ~850#ers with no rear sway bar, and everything is great. But to each his own.
Oh, in the interest of complete disclosure, I have not tried the non-adjustable set on the car. I got them because I needed replacement parts after I tore a corner off the car in a drifting incident, haha.. (and I was able to re-use the adjustable center cartridge part)
Yup, Raj sent me a few pics of that setup. Looks good, wish I had it.
My suspension is currently shot and the tires rub horribly when I hit bumps of indents in the road. Currently running style 32's 17" 5 series offset on 245/40's. I think spaces/camber may help.
How about these Konis?
https://www.newegg.com/Product/Produ...23&ignorebbr=1
I would like to do suspension/rear end all in one go
Should not be running E39 5 series offset in the rear of an E36 with 245 series tires.
You need to roll your fenders if you want to run that combo without rubbing.
Because the offset is 20 so the wheels are pushed out to the fender lips. A stock car can run 245s no problem but 255s even with heavy rolling are a problem and those of us with 275s have heavy doing and our rears are jacked up. That is with stock 40 offset. Reduce to 20 offset and you have even less room. You can tilt the tires in like some kids do but massive negative camber hurts straight line traction and chews up the inside edge of the tire.
Gotcha,
Thanks for the explanation
I have fender flares on the front anticipating that I'd be running wide tires in the future. When I can afford it I'm going to get flares for the rear as well which should alleviate some of the rubbing.
I just couldn't pass up finding a decent set of style 32's in 17 so I had to have them.
Any recommendations for wheels and tires ?
I've got 17x9 arc 8s for sale cheap! Et30
