Page 53 of 78 FirstFirst ... 328434445464748495051525354555657585960616263 ... LastLast
Results 1,301 to 1,325 of 1931
Thread: m52 Turbo Build
  1. #1301
    Virginia
    97' m52 turbo
  2. #1302
    Apr 2006
    Minnesota eh?
    86 325es
    Looks real nice
  3. #1303
    Manchester, N.H.
    96 332IS 6466 turbo
    Compared to the cluster FK many many pages back, I think this young pup is doing well. Looks good.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #1304
    Virginia
    97' m52 turbo
  5. #1305
    Apr 2017
    Florida
    E36
    Nice!!
    wrapping the cold side? Benefits? New to me
  6. #1306
    Virginia
    97' m52 turbo
    Quote Originally Posted by Thompson501 View Post
    Nice!!
    Thanks!
    All depends on your setup really:
    I could see very to little no benefit if your top mount as your taking in the air from your engine bay (and the DP is under the hood as well and that thing gets scorching hot)
    With a bottom mount and especially if the charge piping is under the car in the Winter months here in Virginia with ambient temp of 30 degrees and below I could definitely see a benefit as long as your intake piping is drawing in ambient temp from outside the car as the engine bay temps are higher (and could heat the pipe).
    If I were you I would wrap the down pipe. I saw 200+ degree differences on my exhaust manifold wrapped vs not.
    not wrapped = 450-500 degrees
    wrapped = 200-250 degrees
    In your case your dumping 500 degree heat into your engine bay and it has no where to go.
    Somebody here noticed an improvement at the track with a wrapped pipe
  7. #1307
    Virginia
    97' m52 turbo
    Decided to really get into the car today, dumped first and second for the first time. Car started going completely sideways so I had to let off.
    I've had my fair share of encounters as a youngin'
  8. #1308
    Apr 2017
    Florida
    E36
    Makes sense
    my down pipe is wrapped and blanket on turbo. The headlight cut out is nice being the fresh air goes direct to turbo filter
    definitely more power and seams to spool quicker
    Regarding side ways, lol, the cars like it and are controlable
    glad your enjoying!
    hooe to mail wheel this week
  9. #1309
    Virginia
    97' m52 turbo
    Didn't feel too controllable too me, the more gas the more sideways.
    Thank you
  10. #1310
    Manchester, N.H.
    96 332IS 6466 turbo
    Upgrading your LSD will keep you much more straight. For example, 3 clutch the car still kicks, but 1/2 as much as 2 clutch. 4 clutch the tires spin and you stay straight. This has been my experience with probably 15 LSD upgrades I've done 3/4 clutch.
    1996 332IS
    Built 3.2
  11. #1311
    Mar 2012
    Renton, Wa
    98 m3
    400% accurate.
    Love my 4 clutch.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  12. #1312
    Vancouver, B.C., Canada
    '97 M3
    I was concerned that the 4-clutch would be twitchy transitioning on/off/on power but I have not found that to be the case. It's pretty predictable. What's another $500 or so anyway?
  13. #1313
    Virginia
    97' m52 turbo
    Quote Originally Posted by chikinhed View Post
    Ha, Yeah right. Thats not gonna happen anytime soon.
    I still have quite a few other things I have to get for the car for it to be complete. Its gonna set me back even more.
  14. #1314
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by 328iFun View Post
    His upgrade is much more money than yours. A 188 LSD is cheap to change and add a clutch. 4 clutches get a little more involved, but 3 is pretty cheap.
    1996 332IS
    Built 3.2
  15. #1315
    Virginia
    97' m52 turbo
  16. #1316
    Manchester, N.H.
    96 332IS 6466 turbo
    Yup, simple enough.
    1996 332IS
    Built 3.2
  17. #1317
    Virginia
    97' m52 turbo
    I'll mess with the diff eventually but right now I am absolutely enjoying/loving this car now that its solid.
    Just took the car out again, cant stay out of it. I keep finding reasons to go into town. And I'm pretty sure the cars doing 0-60 in 3.5 - 4 seconds according to a video I recorded (and that's with some slip) pretty impressive if you ask me. I can't imaging what 12+ PSI is going feel like.
    But I wanted to upload pic of drain with the $16 SPA flange installed, puts the hose right where it needs to be and don't have to use as much rubber as the flange is pretty long.
    Once the car is street worthy and I get all the little bits and pieces I need to finish it, I probably wont drive any other of my vehicles for awhile.
    Its awesome telling everyone that I built the car. And there even more surprised when they tell them how I learned to do it and how people I've never even met have taken time to help me so much
  18. #1318
    Virginia
    97' m52 turbo
    I think the cold weather is really making the turbo scream. Can't wait till it gets cold out, I have reasons to look forward to winter now, ha
  19. #1319
    '97 M3
    More power and colder tires is not the best combo but will make your car feel faster.
  20. #1320
    Virginia
    97' m52 turbo
    Didn't think about tires... just cold air for turbo. So I guess temps now are about near perfect
  21. #1321
    Manchester, N.H.
    96 332IS 6466 turbo
    Today I went at it with a fox body, put many busses on his loud thing. ...... But these 265 888's aren't hooking like I hoped. It was probably 65F out, and third gear had no chance at around 21-23#. Car was fully warn, but only drive about a mile. So maybe the tires were cold. Dunno
    1996 332IS
    Built 3.2
  22. #1322
    Apr 2017
    Florida
    E36
    All good stuff, Butters hooked me up with a nice stage 4 and I love it
    i come out of turns on the track in 3rd gear breaking loose and continue in 4th and don't let off.
    5th gear red line at 135 mph on straight away. I'm gonna need another gear, lol
    i always say my next run I'm gonna go easy but it never happens. I feel like I beat the crap out of the car, but it feels so good. Street driving doesn't even do it after the track. Now it's all about adjustments for handling
    sorry about blowing up your thread but I can relate. I am amazed I did This build, but only cause of all the people on this forum!!
  23. #1323
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Welded diffs are almost free, and put down power very very nicely.
    How is the vented turbo drain line working out so far? That's a very interesting idea I never thought of!
  24. #1324
    Virginia
    97' m52 turbo
    Quote Originally Posted by tptrsn View Post
    I've read quite a few pros and cons of welding the diff. I didn't really like what I had read when a few people said they were going around sharp turns and similar obstacles. For straight lines, welded diff would be the way to go but I have a bunch of curvy back roads in my area so I'm not so sure about it.
    All credit goes to Butters on the turbo vent and no issues as long as the vent is long and sits as high as possible in the engine bay. It was nerve racking tapping the oil drain bolt with the pan still on but it was totally doable.
    I used a scavenge pump and a hose in the dipstick tube hole to flush the pan. Mineral Spirits/Reducer or and whatever else I had lying around as solvent. Put oil in ran it for 30 or so miles, drained it and then put fresh oil back in.
  25. #1325
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I don't think you are running 3.5-4.0 to 60 on street tires with 7 psi and a stock M3 diff. The hardest part of driving these cars fast is hooking up off the line. I figure that my 11.5 second quarters at 130+ are about 3.5-4 seconds to 60. The slip does not say but it does give 1/8 and I am usually in the mid to high 7s at just over 100 so I figure 3.5 to 60 and another 4.0 60-100.
    Are you still on a stock 328i auto trans? If so, that will fail soon with the torque you have even at 7 psi.
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
