Page 52 of 78 FirstFirst ... 22742434445464748495051525354555657585960616277 ... LastLast
Results 1,276 to 1,300 of 1931
Thread: m52 Turbo Build
  1. #1276
    Virginia
    97' m52 turbo
    Thanks P.
    This whole experience (coming from someone who doesn't or didn't a turn a wrench or paint very often) has been interesting:
    1. It's amazing what these cars/engines are capable of in stock form with the right compression and tuning.
    2. How enthusiast are willing to help one another. I don't think you would find this kind of support lingering around on other forums for other automotive manufactures or models.
    3. Plain and simple, the best part of all is I can say "I did it" and that the car is absolutely addicting. Everyone who rides with or hears it, loves it. After taken my ole' lady for ride (and she hates speed/torque) she was even interested in what was happening and how it was working and driving the car.
    I think at 7-12 psi, if you can drive the car correctly you may be able to make as much power as the average Joe pushing 18 and not knowing how to drive. And I say 12 because I've seen it creeps to 12 in 4/5th from time to time.
    But it's not over yet, I have a spare motor in my garage that needs built
  2. #1277
    Manchester, N.H.
    96 332IS 6466 turbo
    As for the spare motor, clean it all up, spend $500 on rods (or those nv m50 rods), cut bew stock rings (ill send you the tools to do it) have a proper oil drain welded on the pan and have it ready to go for the lower end. I don't think bothering with pistons and punching it out is worth it. You already have a copper spacer. Then prepare the head. Maybe buy valves, and springs. Have the head cut and install them your self. Then you will have a bullet proof setup.
    Chances are, your m52 will live a long life. I pulled mine at 300k cause Pbonsalb set me up nicely with a s52 and forged pistons. But that 300k m52 is still sitting here in case.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #1278
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Why ATF?
    It flushes out debris better than engine oil since it is thin.
    [IMG][/IMG]
  4. #1279
    Virginia
    97' m52 turbo
  5. #1280
    Virginia
    97' m52 turbo
    Lol.
    Yes, you are correct. atf is thinner than oil. Thinner and cheaper = mineral spirits or reducer if you dump right into pan via dip stick hole
  6. #1281
    Virginia
    97' m52 turbo
    This sounds spot on.
    I don't plan on pushing the M52 too much unless I need too. I've got a couple drag races planned where raising boost may seem fit.
    But as far as my back-road driving 7-10 feels great. I don't like pushing it too much on public roads the car wants to run at 80 cruise and will hit 100 in no time - if I let it. But I really enjoy low speed, fast acceleration, and the torque. Ill often stay in boost till like 60-65 and left off, I just like how fast it gets there and the sounds.
    By all means, walk me through the engine build, ill listen and turn the wrench! Would love a solid setup.
  7. #1282
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I like the idea of the 92 NV rods and stock M52 pistons with looser rings for a durable budget build. Refresh the head and use the ces spacer and cutring.
  8. #1283
    Apr 2006
    Minnesota eh?
    86 325es
    Non vanos rods and head + M52 pistons and crank + S52 cams =
  9. #1284
    Manchester, N.H.
    96 332IS 6466 turbo
    Has anyone tried a set of eBay $279 rods ?
    1996 332IS
    Built 3.2
  10. #1285
    Virginia
    97' m52 turbo
    Look at this on eBay http://www.ebay.com/itm/161145203741
  11. #1286
    Virginia
    97' m52 turbo
    Is absolutely necessary to retighten head bolts at this point? Even at 7 psi?
    Best way to do Without removing cams?
  12. #1287
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    No rod bolts with those. The 279 option has bolts I believe.
    you can fit a socket without removing cams.
  13. #1288
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by 328iFun View Post
    http://www.ebay.com/itm/OTC-5940-BMW...-/400472848952
    [IMG][/IMG]
  14. #1289
    Apr 2006
    Minnesota eh?
    86 325es
    Your saying he should take out his head studs and put stock bolts back in?
  15. #1290
    Virginia
    97' m52 turbo
    Doesn't seem like a good idea...
    I don't think I have a socket that fits with the cams on
  16. #1291
    Apr 2006
    Minnesota eh?
    86 325es
    craftsman and others sell small diameter sockets
  17. #1292
    Virginia
    97' m52 turbo
    I could open a small shop after equipment I've acquired
  18. #1293
    Mar 2012
    Renton, Wa
    98 m3
    The northern tool socket works. So does the craftsman.
    I have used both
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  19. #1294
    Manchester, N.H.
    96 332IS 6466 turbo
    I have been spoiled with 3-4 boxes filled with Snap-on and Cornwell. But, have been paying them bastards $25/week for 20 years so, I guess joke is on me.
    1996 332IS
    Built 3.2
  20. #1295
    Virginia
    97' m52 turbo
    At least you have what you need when you need it.
    Nothing is more aggravating than being in the middle of working on something and not having what you need. Even worse, knowing you have what you need but can't find it or don't have a back up. My shop gets so disorganized when I'm in the middle of something takes me a good day to get everything back in order
  21. #1296
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Opps, forgot he has studs.
    [IMG][/IMG]
  22. #1297
    Virginia
    97' m52 turbo
    Now that everything else seems to working properly I think it may be time to get this $500 meth kit hooked up
    I have a single nozzle, where do you guys think the best place on the manifold would be to tap for even distribution?
  23. #1298
    Manchester, N.H.
    96 332IS 6466 turbo
    Put it pre throttle body.
    1996 332IS
    Built 3.2
  24. #1299
    Mar 2012
    Renton, Wa
    98 m3
    Post maf
    1989 535i - sold
  25. #1300
    Virginia
    97' m52 turbo
    I had it in the Intake Boot initially but boost blew it out
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
