Vent the line.
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I went through this years ago, although I had a pump and stuff. But there is a thread MilkT created long ago that really goes into depth about this. Maybe he can post a link or something. Just vent the line. Also, it will take a bit to clear everything out. More than just idling.
1996 332IS
Built 3.2
328iFun is not having much fun. I hope this latest effort works and he gets to enjoy boost without smoke.
Going to vent line, clean maf, boost leak test and put it on 12 psi
I've inhaled plenty of smoke
Doesn't work
Well Butters did show back up on the thread.
Vent installed
Quick and handsome
Idk what that vent will do.. i think you need a vent above the oil level to allow air in and out.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Cars not smoking so vent did something
1989 535i - sold
*explosion sound*
No explosion sounds... took for a good drive and it ran pretty good.
Gonna drain oil and see if any more flakes come and put fresh in
Lol your a trip
No... not 30 psi. I was joking about that. Wanted to seen
his reaction ..
Butters right now:
Zack could probably make it happen tho
Jordan's buddy Zach ...that works at Active Autowerkes?
WHEW....close one.
I would think Zack 22rpd and Jordan would be arch enemies
Eehh Were facebook friends????
Hah but no.. he tries to smudge shit and start nonsense every chance he gets.. him and his clan.
Milky is upset today, i imagine it'll be a few days before he is normal again.. or well his version of normal :p
1989 535i - sold
