Page 5 of 72 FirstFirst 1234567891011121314153055 ... LastLast
Results 101 to 125 of 1776
Thread: m52 Turbo Build
  1. #101
    Virginia
    97' m52 turbo
    Please post links of good intercoolers -
    Will be mounting to bumper brackets
  2. #102
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by 328iFun View Post
    Treadstone tr1235.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #103
    Virginia
    97' m52 turbo
    Treadstone tr1235.
    Looks pretty solid. Any particular piping kit for bottom mount? Or do you know of a good universal kits with good bends?
    Thanks for the help Butters
  4. #104
    Virginia
    97' m52 turbo
    Prepped the intake manifold today:
    high quality image upload
  5. #105
    Virginia
    97' m52 turbo
    Transmission seems to really be holding me up. Got the new fly wheel, clutch, pressure plate bolted up after doing the RMS twice. The original rms with the spring is 100X better in my opinion, doesn't slide in nearly as easily as the one without.
    Went to slide the TOB on the bearing shaft and it wouldn't move horizontally like its supposed too. Ordered a quality tob one to see if it helps. May also have to order a new shaft.
    Also waiting for a short shift kit, oh and the HG. Waiting for parts is probably the hardest part!
  6. #106
    Mar 2013
    Upstate NY
    M3
    How are you doing your IAT?
  7. #107
    Virginia
    97' m52 turbo
    Quote Originally Posted by Mklock View Post
    That's a good question. From what I've read it's functionality shouldn't effect the DME's readings or the cars performance.
    I'll probably relocate it to the Intake boot.
    Any suggestions on the IAT?
  8. #108
    Toronto, Canada
    E36 Turbo
    What's the reasoning on wanting to move it in the first place?
    E36 DYNO TUNING WIRING PARTS
  9. #109
    Virginia
    97' m52 turbo
    To summarize everything thus far:
    - Head has been resurfaced and new seals have been installed
    - SPA T4 Exhaust Manifold will be used
    - TIAL 38mm wastegate. Im thinkin the WG will vent to atmosphere for awhile and I plan on using .2 bar spring to start.
    - Rally Road Engine bracket with new engine mount
    - GR35R was originally purchased and returned due to bad bearings (fleabay)
    - Precision 6262 JB was ordered instead (brand new this time) JB will make install easier
    - Oil will be fed from vanos feed
    - Oil will be returned via switchable scavenge pump from cabin to dip stick tube hose from CCV
    - Cut ring HG/and Copper gasket
    - ARP 2000's
    - All intake gaskets will be replaced
    - IAT will be relocated to intake boot
    - AEM Meth kit will be used with the nozzles installed in the intake manifold
    - Technica wally 255 drop in fuel pump
    - Waste gate will receive vaccum directly from the turbo
    - Treadstone TR1235 intercooler
    - 330 Brakes (thanks butters) because I'll have to be able to stop... He may have saved my life
    - Intake manifold tapped for boost connections for meth controller, BOV, and boost gauge. Will be using 1 piece silicone tubing for ICV. Empty end from CCV will be blocked off. Fuel pressure regulator will use m50's existing nipple. CCV tube from side of intake will replaced with a standard air filter.
    - Installed a GRIP stage 3 clutch/flywheel package. If you decide on one of these kits it might be a good idea to go ahead and order a quality throw out bearing. The TOB that came with my kit was garbage (probably Chinese). You can order a sachs/timken or equivalent TOB for around $40-$90. Might also want to look into getting a replacement TOB shaft. Vehicles with high mileage will show wear on on the shafts preventing the TOB from moving freely.
    - RK Tunes will be ordered and used once everything is installed and buttoned up
    - You guys may flame me for this: But I intend to keep the stock exhaust which has Borla catback installed. Seeing as the turbo is a bottom mount I would suspect a good downpipe would almost line up with the stock system when cut after the headers. I could use the existing O2 bungs for bank 1 (rk tunes) and the AFR. This could reduce costs substanially but I wonder how much the 2x 2.25" stock pipes will restrict spool? In theory, wouldn't they equal about a 4.50" single pipe?
    You guys have helped me figure out everything above and I've pretty much followed everyones advice to the T. But I still need ideas on:
    - Electronic Boost Controllers
    - AFRs (accurate gauges)
    - Boost gauges
    - How about oil pressure to the Turbo? A way to monitor it.
    - Does anyone have diameter specs for the blow through maf eblow supplied by RK tunes? I'll need to make charge piping to it. Ill email Jordan if I have too.
    Am I forgetting anything?
    Thanks again everyone
    Oh and I'm thinking this body kit. I could pull it off once the cars boosted:
    http://www.tf-works.com/rocket-bunny-kit-bmw-e36/
  10. #110
    Virginia
    97' m52 turbo
    Quote Originally Posted by NOTORIOUS VR View Post
    Wont the meth effect its readings? Not sure how it would act if its getting sprayed by meth
  11. #111
    Apr 2006
    Minnesota eh?
    86 325es
    It won't matter if you get meth on the sensor. Why put the scavenge pump on a switch? I guarantee you will forget it eventually. Better to have it on whenever the key is on or powered whenever the fuel pump is on. Duel 2.25 pipes are about the same flow as a single 3".
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  12. #112
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Agreed.
    Awful idea. .
  13. #113
    Virginia
    97' m52 turbo
    I just don't like doing relays...
    I guess that makes sense though. Fuel pump it is
    Guess Ill go with stock exhaust
  14. #114
    Feb 2012
    1995 BMW M3
    You need a separate relay for that scavenge pump , do it right.
  15. #115
    Apr 2006
    Minnesota eh?
    86 325es
    You can't run both off the same relay, it will overload it and drop voltage to the fuel pump. I would run the scavange pump of the existing fuel pump relay and then put a new relay in the trunk wired off the battery with a 40 amp fuse to run the pump.
    does this make sense?
  16. #116
    Virginia
    97' m52 turbo
    Yes makes perfect sense. That's exactly what ill do. Thank you
  17. #117
    Virginia
    97' m52 turbo
    Got the head installed today. Rigged up a winch which made it really effortless
    to upload photos
  18. #118
    Feb 2012
    1995 BMW M3
    Haha omg that's funny.
  19. #119
    Virginia
    97' m52 turbo
    Ha, funny but functional beyond belief. I can say 100% that the rings/gaskets didn't move and the head is perfectly aligned. I am around 97% sure I wont have any issues with head gasket sealing.
    That's the same board and winch I used to pull the chimney liner out of my flue, talk about a PITA... That's a whole another story though. Glad I got another use out of it.
  20. #120
    Feb 2012
    1995 BMW M3
    Really should have put that manifold on before you put the head in though.
  21. #121
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    I had it on originally when I was trying to muscle the head on. I took it off thinking it would help and it did a little but I still wasn't comfortable with it.
    I didn't think to reinstall it after I thought of using the winch. Its gonna be a pain to install now but oh well. Since the transmissions out I'm able to tilt and lift the motor as needed.
  22. #122
    Apr 2006
    Minnesota eh?
    86 325es
    Hey that's cheating! I pulled the head of my truck this weekend by hand and the head off a Cummins weighs 200 lbs!
  23. #123
    Virginia
    97' m52 turbo
    Holy crap. You need a winch
    I miss my turbo diesel
  24. #124
    Virginia
    97' m52 turbo
    I was pretty tired when I got home from work yesterday but I managed to get the rally road engine bracket installed and perform a manifold and turbo mock up. Everything seemed to line up really well but there aren't too many options for waste-gate. I went with the SPA wg tube and a 2 bolt 38mm to vband adapter which should arrive soon. I also received a brand new PT6262 for a price I am not at liberty to discuss.... just kidding. Will be reinstalling the transmission this weekend, god help me. There will be cussing Im sure, any tips? I dont see the thing 'sliding' in to easily. Im also looking for good quality silicone couplers. I plan on running the turbo intake first its, 4" in diameter.
    I keep wondering how I'm going to test drive this car when its all said it done considering its completely torn apart cosmetically. Ha
  25. #125
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I don't remember it being quite that heavy? I've had to bring a 24v head to the machine shop after a leaking injector lifted the head.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 10:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 11:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 03:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 04:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 12:17 PM
