Page 46 of 78 FirstFirst ... 2136373839404142434445464748495051525354555671 ... LastLast
Results 1,126 to 1,150 of 1931
Thread: m52 Turbo Build
  1. #1126
    Manchester, N.H.
    96 332IS 6466 turbo
    Here was my solution
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #1127
    Mar 2012
    Renton, Wa
    98 m3
    m52 Turbo Build
    1 more vote for butters solution
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  3. #1128
    Vancouver, B.C., Canada
    '97 M3
    Ya, why are you messing around wasting time on a difficult to get to marginal solution when all you have to do is drill and tap the oil pan. Put some grease on the drill bit and tap flutes, drill slow as aluminum doesn't care about speed and flush it with solvent a bunch of times.
    I went through the same smoke issues years ago. I tried some of the magic that has been suggested except for the sump and the vent. Check valves on the inlet and outlet of the scavenge pump, a timer set to run 45 seconds after engine shut down, drain into the oil pan.... what fixed it was a 1 psi check valve on the feed line to stop oil flowing into the turbo after shut down. The old guy at RB Racing told me that's what the fix would be and he was right. Back when Horsepower Freaks were a thing they had the same issue with some kits and released a service bulletin to install a check valve on the feed line to fix the issue.
    My .02
  4. #1129
    Virginia
    97' m52 turbo
    I've never tapped an oil pan or much of anything for that matter. That's why I'm trying to avoid it. Especially with oil pan on
    If you can guys can tell me what to get to do it correctly. I'd give it a shot
  5. #1130
    Virginia
    97' m52 turbo
    I would like to use this fitting. its 3/8
    https://www.amazon.com/Straight-Flar...s=8+an+fitting
    So a 3/8 tap and a 3/8 bit?
  6. #1131
    Virginia
    97' m52 turbo
    Would this work?
    https://drillsandcutters.com/3-8-24-...SABEgIAmPD_BwE
    And I guess I would have to buy the part that spins it too. Not sure what its called though.
    And for solvent just flush with oil
    thanks again
  7. #1132
    '97 M3
    I would go for -10 on the drain, 3/8-18 NPT tap and a 9/16" drill bit. That tap you posted is not NPT. For a solvent use varsol, stoddard solvent or mineral spirits. You can get any of those solvents at a hardware store. (Never use soap and water).
  8. #1133
    Virginia
    97' m52 turbo
    Quote Originally Posted by chikinhed View Post
    So just pour solvent in the pan several times and it should be to good?
  9. #1134
    '97 M3
    Grease the flutes, that will catch a bunch of the debris. You can hold a vacuum cleaner beside the drill if you'd like. Thee remaining debris can be rinsed out with solvent.
  10. #1135
    Virginia
    97' m52 turbo
    Ok I'm going to do this.
    If you guys know any good brands or websites with a kit or whatever for 3/8npt please post a link and I'll order
  11. #1136
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Can you get a drill on top of the pan on the drivers side with the engine in the car? Butters did his with the engine on a stand. I welded a bung on mine when the pan was off. If you want to return to the top of the pan on the turbo side, you can do that more easily. Then you would not need the scavenge pump assuming your turbo sits high enough. If drilling the pan on the turbo side, try to drill at an angle so tbe fitting wont end up pointing downwards. Some have returned to an enlarged pan drain. Home Depot and Lowe's sell 3/8 NPT tap kits but borrowing one is cheaper. If your turbo is installed there might not be room for a drill. Maybe a right able drill with a stepped bit?
  12. #1137
    Virginia
    97' m52 turbo
    I could enlarge the drain bolt?
  13. #1138
    Virginia
    97' m52 turbo
    That's probably be easiest
  14. #1139
    Jun 2005
    New England
    Butters has does it for cars he has built. I think one uses a 6262 journal bearing.
  15. #1140
    Virginia
    97' m52 turbo
    I wouldn't need a vent or pump would I?
  16. #1141
    Virginia
    97' m52 turbo
    He had told me tap the plug months ago.
    But didn't do it becuase I didn't wanna mess it up
  17. #1142
    Manchester, N.H.
    96 332IS 6466 turbo
    The car I did that to, actually 2 of them. I drilled out the drain plug to fit a 1/2 npt. He is a member here, no smoking with a JB 6262. I also made a vent line tho. You can't really screw up the pan much, the bonus is that you just dump a at of dino oil down through and it all flushes out.
    1996 332IS
    Built 3.2
  18. #1143
    Virginia
    97' m52 turbo
    Butters if you have a second can you post what tap and size bit you use to accomplish this or pm me.
    I'm going to do this with a vent and be done with it
  19. #1144
    Virginia
    97' m52 turbo
    Should have did it from the beginning
    Live and learn I guess
  20. #1145
    Manchester, N.H.
    96 332IS 6466 turbo
    45/64 bit and 1/2NPT-14 tap
    1996 332IS
    Built 3.2
  21. #1146
    Virginia
    97' m52 turbo
    Thanks butters
  22. #1147
    Jun 2005
    New England
    Butters to the rescue. Should have listened to him months ago. There is the hard way and the easy way. Try the easy way now that you have attempted the hard way.
  23. #1148
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Yup, my car is the one in question that this was tested on. 12k miles later with daily driving, still no issues here.
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  24. #1149
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    Butters also instructed me to do the same, turbo drains well. I have an extra new tap I can send you...or go on amazon and get the tap and drill bit, they have them on there for reasonable. For the fittings google your closest city and aeroquip.
    This place may be able to help you. You just need a 1/2 npt to -10 then whatever you are going to use for the drain. You could prob have them fab you a line once you figure out the length.
    http://www.tipcotech.com
    or the place below may be able to help.
    http://www.colliflower.com
    1/2 npt to -10 fittings
    https://m.summitracing.com/search?ke...20to%2010%20an
    Tap on amazon is “dwtpt1/2”
  25. #1150
    Manchester, N.H.
    96 332IS 6466 turbo
    You can also get a 1/2npt to 5/8 barb from home depot.
    1996 332IS
    Built 3.2
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
