It's going to be a pain in the arse. I can barely get a wrench on those bolts...
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
To see how far from vertical the drain is. BW and Garrett recommend max 20* I believe.
Anyone know what pte recommend ?
I have had mine clocked that much "both ways" without an issue. I needed to do this when I was running a WG built into the housing.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Yeah bb's are way more forgiving as the quantity if oil is like 3L a minute in jb vs 0.5-1L/min in bb
Garrett recommends <15*
I feel pte would be less but thats unsubstantiated
Remember you have a Jb with no restrictor you have to be very careful.
1989 535i - sold
Mine is clocked as much as yours and I'm running a 4an unrestricted feed.
Maybe im wrong. But looks far for me.
Raj also runs borg, maybe they handle angle better.
Like i said if you run out of options you may want to try it. I had to clock a turbo once or twice... even a water cooled one
1989 535i - sold
Borg for the win. Pretty sure I could clock my turbo upside down and it still wouldn't smoke lol.
He also has a sump.
1989 535i - sold
How many miles have you driven since you flooded the exhaust with oil? If it is 500, then I agree the oil should have burned or been blown out.
"Maybe 5 or so miles of heavy driving and tons of idling. When it initially happened I let the car idle for a long time before it stopped smoking."
Once you get the current drainage issue sorted out and are back on the road, don't be surprised if you blow smoke when you get on it at full throttle and full boost. until more old residue clears out.
Well,
Its worked fine up until this point. When I mean fine, I mean zero smoke as long as I ran the pump for 30-40 after shutdown.
I guess the turbo said, well "f this, I don't like the direction I'm facing so I'm going to be a assh*ole now and start to smoke" haha
I really don't know. It would seriously take a good 2-3 hours minimum to re-clock it, scratched arms, cussing, and all, if I can get to all the bolts that is.
I might need to take a break from this thing for awhile guys. I've been going hard for like 7-8 months straight in my spare time and have gotten like maybe 60 miles out of it and 6 to 7k later...
Might pull the car into a nice little spot in my garage and let it sit for awhile
As far as precision being junk, mines made the car pull pretty good, not sure. There are plenty of guys that here and elsewhere that use them. Most people who are salesman usually hate the company they work for unless they are making XX amount of $'s. I hear people talk smack about where I work all the time and other places as well. If it were an engineer at Precision saying that I may think it were true.
I seem to be back at well the try this stage which resulted in a lot of time and money the last 2 times, lol.
I have a precision too
1989 535i - sold
Ha, I guess you didnt take his advice then!
Hopefully yours doesnt decide to be a little bastard
1989 535i - sold
Viscosity cold
1989 535i - sold
Your exhaust in the turbine housing is very hot
1989 535i - sold
