Butters already schooled me about the gas light...
I don't have access to a pump right now I've been using a can
FYI, newbies, don't run gas low because it could cause the car to lean out, which = death.
I had a sharp eye on the AFRS, they were in the 11's while in boost and I put a bit of fuel in before driving and it was in a straight line for maybe 2 miles total. I had had an idea that it wasn't good to run it low but sometimes you just wanna drive...
I think I've found my drug
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Haha
This is my signature....
Watch the boost load near the end of the second vid. That is intense for 7
https://youtu.be/epXq1-X7gYg
Another video. Barely touching it
Might wanna check that link lol
Plan on maybe bumping it up a lil this weekend
Would love for Zack to view some logs before. But he's gonna be away for awhile
I think this turbos efficiency hits full at about 80 mph.
It does have a small back housing.
I can view logs..
1989 535i - sold
1999 M3 Tiag/Dove - sold
Thank you for this Butters...I am lucky to have bought a well-sorted car. However, It's good to know that everyone on here is willing to help. I'm doing my best to learn as much as possible.
OP, didn't mean to hijack, I've been learning from your struggles as well. All learning together....
I really don't want take the intake manifold off again.... it would be like the 76th time
This is a hole I had plugged with a bolt and epoxied it. It was too big for the bolt and was leaking.
Any ideas on plugging it with the manifold staying on?
Needs taper threads. Find a taper that fits.
1989 535i - sold
Man your quick!
Gotcha will do. Makes sense. Smaller threads = more grip.
Just didn't know the term
I think he means like npt...they are smaller at the start and get wider as you screw it in.
you can get npt plugs
Thanks both of will start looking around this weekend
Correct npt. Depo/lowes will have one
1989 535i - sold
