So I ran out and bought an O2 sensor today. No improvement.
About $600 later I decided to swap in the stock DME, Injectors, and MAF.
and lo and behold , the car runs great?
Bad dme ?
Who knows
Whos tune/DME?
I'm glad I kept my DME, pink injectors, and MAF
Otherwise, I don't know what I would have done...
To anyone reading this who wants to go turbo. Keep your stock equipment for troubleshooting
Having extra, serviceable, sensors is always a good thing. They should go in a small tool kit for road trips. (Learnt from experience).
So the tuner thinks it's tune related n not hardware ???
The sad part about this all:
I bought this car probably, say 7 years ago. For $5500 with I think 120,000, since then I've put maybe 18,000 miles on it. I've invested 3x what I paid for it
We don't, but were going to try a few things. If we cant get it to work today ill ship him some parts to try. So today it'll either run or we will know why it isn't running.
We would have done this the other day but the wacky fuel pressure postponed it.
-Zack
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
Not sure at this point
I bought a spare maf, no change.
I'm betting DME. This would explain all the circuit related codes I was getting
Got them for
Camshaft sensor
Crank sensor
O2 sensor
And I tried 3 different O2's, 2 of which where new out of box and the circuit code still came back
But you can bet that after going through all of this I'm going to shoot for 550whp
Gonna push through this mess. Looks like Mad boost scientist garage. Freaking mess...
Hopefully it will be a good day
60lbers back in
In the end its worth it. It's when you get greedy you can regret. Even then, totally worth it and you won't give it up.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Boot all clamped up
I had a dyno confirmed 450+whp 2010+ Camaro in the shop the other day, now to the general public this is a fast car. Let's face it, a c6 z06 stock is in the same area. I was looking for a vibration under heavy load. This was customers complaint. So, out for a ride. I don't think I could even slow my car down enough to lose to this car. It was a total joke. My point is, push through this crap, take it as experience, knowledge, learning how things work, and enjoy it. Having a car like your building , you should really know how it all works, and this is forcing you to sort it out now. This is a great thing. Cause when you decide to be running upper limits of your setup, and your not all sorted out. That's when things get expensive.
But, like the story above, even then its worth it. Cause it will cost you 50k to even think about getting the thrills your gonna get.
1996 332IS
Built 3.2
What's up 328ifun
been watching your post and have not commented because I don't know crap.
i do know, don't give up. It will be worth it
hope the best for you
