Page 3 of 78 FirstFirst 123456789101112132853 ... LastLast
Results 51 to 75 of 1931
Thread: m52 Turbo Build
  1. #51
    Virginia
    97' m52 turbo
    Quote Originally Posted by Fender13Bender View Post
    I've got an aquarist setup I'd sell you
    How much?
    Would you mind helping me install it if I have any questions?
  2. #52
    Virginia
    97' m52 turbo
    Side note:
    Any computer geeks out there?
    Gotta a super computer for sell:
    Liquid Cooled i7 4790K OC'd to 4.7ghz
    32GB Ripjaws X
    (2) GTX Wind Force 1070 SLI
    Radeon HD70 (desktop graphics) so main monitor can be in SLI permanently.
    Elgato Game Capture HD60PRO
    6 Solid State drives (4) in raid 0 with windows 7 and 10 installed in
    3 Mechanical Drives (Green) (1) 1TB (2) 2 TB
    RAID Controller
    LG Blu Ray Drive
    DVD Multi Drive
    Touch LED Fan Controller
    RGB LED Strips with wireless remote
    etc...
    Just though id throw it out there :-)
  3. #53
    Manchester, N.H.
    96 332IS 6466 turbo
    That will sell fast.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #54
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Interesting
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  5. #55
    Virginia
    97' m52 turbo
    Quote Originally Posted by dovlet View Post
    Interesting
    TheComputer?
  6. #56
    Virginia
    97' m52 turbo
    I've been looking into the best option for injecting meth into the intake... Mocked this up real quick.
    cdn images
    The goal is to keep the nozzles as parallel to the intake runners as possible. Really, the only main concern that I've read in regard to Meth on the m5x engines is equal distribution and I'm thinking something like this may help alleviate the problem. Oh, and pumps not turning on/or off when they're supposed too
  7. #57
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    That looks similar to what I did last year. But for 15 years before that, I used just one or two nozzles before the TB and that seemed to work fine.
  8. #58
    May 2016
    Riga
    e30, e36
    I rewelded this type for upper mount. If You want this as bottom mount, you will need oil pump and intake piping is pretty dificult to sort out.
    Quote Originally Posted by 328iFun View Post
    Thinking about getting this manifold today:
    http://www.ebay.com/itm/Active-Autow...5YvzsZ&vxp=mtr
    Its a used AA bottom mount. Anyone know anything about these and their functionality?
  9. #59
    Virginia
    97' m52 turbo
    Dropped the cylinder head off at a automotive machine shop the other day that specializes in hot rods/drag cars. I asked the owner how he felt about rebuilding the entire unit and he complimented BMW on how well their engines are built and hold up. This was coming from an older guy who primary works on V8's and muscle cars so I thought it was a good assurance and a compliment none the less, he said there was no point in rebuilding the entire head at 130,XXX miles. I was pretty glad to find a shop close by that specializes in this type of work.
    Head will be resurfaced and receive new valve seals.
    With that said, my turbo is supposed to arrive on Friday. I've been looking around for oil/coolant fittings for the GT35R and stumbled across oil restriction for Garrett ball bearing cartridges. After doing plenty of reading on whether or not I need a bolt that restricts the oil flow from the vanos banjo bolt is still somewhat unclear. Anyone running the with a restrictor? I read that oil PSI for the m5x/s5x engines is anywhere from 10 (at idle) to 40 (at acceleration). As for the coolant lines, ill use the ones that are connected to the TB.
    Was also thinking that a scavenge pump would be good assurance since I'm tapping the oil drain plug. I think it would keep the oil flow on the return side.
  10. #60
    Jun 2005
    New England
    I used a restrict or with my gt3582r and -3 line. I would only use a scavenge pump if you need one because your manifold is too low for a gravity drain. I used one for years with no issues but had no choice due to the manifold. Now I have a higher mount manifold and do not use one.
  11. #61
    Virginia
    97' m52 turbo
    What diameter did you use for restriction? .035 or .040? From most of the bottom mount pics of the SPA I've seen it appears that it sits high enough to properly drain into the oil plug outlet. Hell, if Butters recommended it I don't see problem with it but I you never know. Scavenge pump would be piece of mind
  12. #62
    Manchester, N.H.
    96 332IS 6466 turbo
    I think anywhere you put a drain on the pan it will be in oil.
    You can pull the pan, drill it , clean it, weld a fitting on up high. Hope you got the right angle. Or, you can take a 23/32 bit blow out the drain plug hole to 1/2" NPT and use home depot fittings. Worse case scenario ? You now have a 1/2" npt drain plug if it doesn't work.
    That said, I run a scavage pump.
    1996 332IS
    Built 3.2
  13. #63
    Virginia
    97' m52 turbo
    Where to?
    Would this do the trick?
    https://www.amazon.com/Vibrant-10297...s=1%2F2+npt+45
  14. #64
    Virginia
    97' m52 turbo
    Where to?
  15. #65
    Virginia
    97' m52 turbo
    Go ahead and do it now question?
    The last time I experienced boost was in a 2005 ford 6.0 and it was addicting.
    With that said I was speaking with a really great friend of mine I showed him pictures that I have shown you all and he said since the motor is where it is now it would be a good idea to go ahead and pull it and build it up for more power.
    With my power goals in mind and everyone's experiences here what do you suggest? Will I be OK on stock internals or should I just go ahead and bite bullet now and build the lower end?
    And I really do appreciate everyone's feedback, this thread is a prime example of why owning E36 is so great.
  16. #66
    Apr 2006
    Minnesota eh?
    86 325es
    Rods and pistons will make you feel warm and fuzzy and takes away some of the anxiety. Writing the checks and waiting for the machine shop to get around to boring and honing your block, not so much. I'm impatient so I build all my own junk. If I can't do it at home I just don't do it. Just to save you future disappointment, if the machine shop says it will take a month, plan on 3. If they say 3 months your not getting it for a year.
    Third option is if the bores do not have a ring ridge at the top, ball hone it at home and get some stock bore wiseco's
  17. #67
    Virginia
    97' m52 turbo
    Got this thing in today:
    how do you upload photos
  18. #68
    Manchester, N.H.
    96 332IS 6466 turbo
    What the hell is that thing ? Some sort of air horn ?
    1996 332IS
    Built 3.2
  19. #69
    Apr 2006
    Minnesota eh?
    86 325es
    Definitely a salad shooter
  20. #70
    Virginia
    97' m52 turbo
    Works great for grading cheese, especially when I hook a vacuum up to its tube. Multi purpose tool perhaps
  21. #71
    Virginia
    97' m52 turbo
    After spinning the turbo by hand today for a while, a sound appeared. Pretty sure the bearings in this thing are shot...
    View My Video
    Bummer :-(
    eBay seems hit or miss now a days. I don't remember it being quite as bad awhile back. A lot of the sellers are rude and simply don't know how to do business properly. I hate when people waste my time.
    Anyway,
    If you guys don't mind please keep a good look out for a WORKING gt35 or equivalent compressor for this build. Thanks again
  22. #72
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Shouldn't be spinning a turbo with no oil in it. Either way though, no amount of oil is going to fix that issue.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  23. #73
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Can you not return it?
  24. #74
    Virginia
    97' m52 turbo
    Quote Originally Posted by somebody5788 View Post
    I know, but Im glad I did before I bolted it up.
    Originally the item was posted with no refunds but the guy said he would let me return it.
  25. #75
    Feb 2012
    1995 BMW M3
    That's good. I'm pretty sure if smething is advertised in working condition it doesn't matter if the seller says no refunds if the part was not as advertised anyway. Ebay would step in there I believe.
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
