Page 28 of 78 FirstFirst ... 318192021222324252627282930313233343536373853 ... LastLast
Results 676 to 700 of 1931
Thread: m52 Turbo Build
  1. #676
    Virginia
    97' m52 turbo
    Alright so I've replaced almost every sensor on the car except o2 and MAF.
    At this point I'm thinking about swapping over the m52 manifold from my spare motor too see if it effects idle or replacing the o2. There's no change in idle when the o2 is unplugged, so I don't know if the o2 could create a bouncing idle or not. Couldn't find anything searching turbo builds. The o2 is new but it may have gotten oil on. Only reason I haven't replaced it yet is because of $. From what I've read the car should go into open loop if the sensor unplugged
    I may also swap in the stock DME, injectors, and MAF to see how the car runs
    or
    should I skip all of that and do a smoke test? I'm certain all of my connections are secure under the manifold but I'm thinking there may be a leak at or to brake booster or somewhere else I cant see
    please help point me in the right direction!
  2. #677
    Manchester, N.H.
    96 332IS 6466 turbo
    Check the MAF for oil coating. Spray the MAF with cleaner and redrive. Take care of the o2 as well.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #678
    Virginia
    97' m52 turbo
    Thanks Butters,
    Zack (22rpd) and I tested the MAF for voltage last night, he said it checked out fine at around .60-.80v.
    I ordered an o2 and will swap out this evening and report back, $109.00. I am broke as a joke. I hope it fixes it
  4. #679
    Va
    I had similiar issues with my e30 when I put it together, pulled my hair out. Finally found that the IACV was stuck, cleaned it got it freed and it was fine after that
    Back into a BMW, this time a track rat....and it won't be BMW powered and no, not a V8 either!
    Couldn't help myself, boosted e36 m52 street car in progress also!
  5. #680
    Virginia
    97' m52 turbo
    Quote Originally Posted by exvitermini2 View Post
    Man, you have no idea how bad I wish it were the IACV!
    I've cleaned the original IACV that was on the car and took the IACV off my spare (identical) to no avail
    you got lucky
  6. #681
    Virginia
    97' m52 turbo
    Alright guys now fuel pressure gauge is bouncing and idling is even worse from fuel rail:
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  7. #682
    Virginia
    97' m52 turbo
    WOW
    So I replaced o2 and Crank sensor, still have codes
    P0135, o2 Sensor Heater Circuit Bank 1 Sensor 1
    P0335, Crankshaft position sensor A Circuit
    car is running like COMPLETE shit now
    I'm seriously about to throw in the towel. I enjoyed my 40 miles of interrupted boost. But I've been simply trying to get this car to correctly idle since last Saturday
    If anyone's will to buy any of this stuff, here it is, 40 highway miles: Ill let it all go for 3.5k
    Complete Turbo Kit:
    Precision 6262 Journal bearing
    22rpd base tune with ECU and OBD connector, and time for revisions
    SPA manifold T4
    SPA wg tube
    Turbo smart waste 7 psi spring 38mm vband
    Zeitronix data logging
    Eboost street 2
    60lb injectors
    Walboro 255
    2 Scavenge pumps
    M50 tapped for boost
    Cylinder head with new valve seals
    ARP Studs
    Copper spacer
    38MM BOV
    Charge Pipes
    Treadstone 1235 Intercooler
    Downpipe
    (2) SPAL Fans
    Low temp thermostat
    Mishimoto Rad
    All hosing
    Vanos tap for turbo
    Turbo feed line
    and more...
  8. #683
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Damn you really parting it out !!!!
    That's sad but Pm me about Zeitronix data logging and eboost
  9. #684
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    U should t give so easy. It's prob something simple that your overlooking
  10. #685
    Nov 2013
    VA
    E36
    I was at this point after the machine shop f*cked up my first head. I was getting zero comp in all cylinders. Had to buy new hg and head. Keep pushing bro. You have unlimited technical support from bforums.
    Sent from my XT1585 using Tapatalk
  11. #686
    Nov 2014
    Bellingham, Wa
    1995 325i, 1998 M3 Coupe
    Have you swapped out the o2 heater relay or checked for power at it? Might also be worth checking your timing.
  12. #687
    Manchester, N.H.
    96 332IS 6466 turbo
    Fuel pump could be sucking air causing the FP change. But if vacuum is bouncing then FP will bounce. Did you physically pull the MAF to check for oil ? Are you clearing codes properly ?
    Disconnect the battery then drive it. Remember these cars need to adapt.
    1996 332IS
    Built 3.2
  13. #688
    Virginia
    97' m52 turbo
    The car was idling pretty good. When I shut it off and then started it back up with no changes it idled terribly.
    I bought a brand new MAF, no change
    I've swapped the cam sensor and I still get pending codes
    I've changed the crank sensor still get crank code. It's not OEM but it is new
    I've bridged the fuel relay, I've connected the fuel pump directly to power.
    I bled the fuel pump rail.
    I've felt, shook, clamped, tightened and reclamped every single vacuum hose, clamps, manifold bolts, tb bolts that could effect idle literally 15 times and it has little to no effect on idle
    I've taken the intake manifold off and checked gaskets and connections 5 times
    I've swapped out the vanos
    solenoid 4 times
    The camshaft sensor i have 2 of them I've swapped it probably 5 times
    I've plugged and verified and unplugged all manifold connections 10 times
    I've tried 2 brand new o2 sensors I've spliced, respliced, plugged unplugged 15 times
    I've swapped out the iacv 4 times, I've cleaned them twice
    I've checked any cabling or hardware that I have come into contact with to ensure I haven't screwed anything up
    I've checked compression 5 times
    I've swapped plugs 2
    I've swapped every single coil pack 3 times
    I've temp checked the exhaust manifold for variances in temperature
    I've checked vehicle voltage at battery, may need a new alt and battery
    I'm starting to lose my sanity. I've spent 40 hours since Saturday chasing my tail and its worse than what it was
    When I put the car back together it ran perfectly on first start caused I made sure everything was correct...
    I don't get it
  14. #689
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Disconnecting battery won't do anything on obd2 cars. But using a higher level scan tool to reset adaption could help.
  15. #690
    Virginia
    97' m52 turbo
    It will barely hold idle or even start now
  16. #691
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    As easy as it is to start the car and unplug the electrical connector on the IACV i would have thought you woul have done it even if its to tell me im crazy. But here goes I'll explain
    even with a good iacv the idle can hunt. The OEM or even tuned IACV is has a mathematical model that tells it how much to open and close over a given amount of time based on the physics of the motor the model was tuned or developed for. Part of this model is to uses rpm feedback and other parameters to land the comanded value smoothly on the actual value with an expectancy window that we tell it to try again if it (mid move) is not where its suposed to be.
    so imagine that one of the variables that provides feedback to the math model is a little off. It cold undershoot the target or overshoot the target. So the expectancy window throws it in the opposite direction. 1 of 3 things happen. On reveral it overshoots another window and throws yet another reveral at it. So it either drifts into the right window, drifts by the window, or hits the target.
    so you get a decaying oscilation an increasing oscilation a steady oscilation or you hit it on the head.
    if you unplug you get nothing but it eliminates the timing, fuel, and iacv compensations. If the car dies when you unplug you get to open the throttle plate idle adjust and tke a bunch of crap for touching the untouchable.
    you adjust it to where the car jst stays running and decide you dont need the iacv. Or you decide im going to open it up further while the car is running and all holy hell braks loose with mixtures and rpm and then you unlug and call it good enough. Or you push through the storm and keep opening the idle adjustment and remember some smat a** was whining you forced him to write a book for an experiment that is just as likely not the same as his problem was s it is that al the same indicators led him to solve his problem this way. Touch the untouchable but only half of the tuning tables are going to work when you have the CEL. My rpm oscillation had 1 second the .5 second then .25 second intervals and then dead silence when the CEL was not on and the PID loops for fuel, IACV, and ignition stayed in 1 table and fell into the expectancy window.
    the iacv retards and advances idle speed. Its a very fast continuously varable bi directional valve that is corrected by several other tables that lag the valve......thus the need for the math model to begin with.
    Friction, inertia, temperature, afr, .......the model compensates for a limited amount of variation.
  17. #692
    Virginia
    97' m52 turbo
    Quote Originally Posted by bry195 View Post
    Thanks for the write up.
    I've tried unplugging the IACV briefly.
    The car was running great with the IACV initially which leads me to believe that the its not the problem. But id be willing to leave it unplugged at this point to see if anything changes...
    this is a video at idle before sh*t went south, the car was idling/revving beautifully
  18. #693
    Virginia
    97' m52 turbo
    I just got to thinking as I was reading over this thread: https://www.bimmerforums.com/forum/s...ning-Turbo-Car
    Where voltage appeared to be the issue with his turbo e36.
    I never really thought about it but I've had to jumpstart my car several times with my battery jumper to get it to start back up after turning it off. This has happened numerous times to the point where I've just left the charger connected to the car. I never really though about it.
    I happened to put a multimeter on my battery last night after I shut the car down and it read around 10v. This morning it read around 11.50v.
    Could a bad alternator cause of all of these problems? I've left the car connected to the charger with it running to boost voltage to see if it helped any, it didn't.
    I do have 2 electric fans, 1 scavenge pump and then all of the other turbo accessories connected to the car
    The car was idling the worst it has in awhile last night the RPM gauge would bounce all the way the way up and all the way back down?
  19. #694
    Mar 2016
    greece
    bmw 325i 1998 coupe
    Quote Originally Posted by 328iFun View Post
    yes ,it has happened to me ,the alternator was bad ,it didnt charge the battery right and the car start to lean out probably because the pump has not enough power to work as it should ,i figured it out pretty quickly though because after 2 days the battery was dead and it didnt crank at all
  20. #695
    Virginia
    97' m52 turbo
    Quote Originally Posted by dkech View Post
    Hmm, maybe onto something here. I've had this issue for awhile now, where I constantly have to let the battery charge or connect my jumper box. I should have sorted it out sooner.
    Whether its the problem or not, it needs corrected
    Also got to thinking about lean conditions and there are so many variables, tune aside that could cause these cars to run lean at anytime whether its in boost or not. Not a good thing
  21. #696
    Mar 2016
    greece
    bmw 325i 1998 coupe
    dont know if its the solution but it could be ,otherwise i recommend contact your tuner to dial in with the tune maybe
    here is two vids of my car ,the first is normal the second is the night before the alternator die completely,check the difference in afr readings
    https://www.youtube.com/watch?v=OYtlXFe3XE4
    https://www.youtube.com/watch?v=QD6lkqet3S8
  22. #697
    Virginia
    97' m52 turbo
    Awesome, thank you.
    What about idle? Mine may be in much worse condition than yours was. Looking at sourcing an alternator now. At least I can get that out of the way. My car sat for a good 2 years and wasn't driven much due to a wasp nest, I was stung several times. So I'm sorting all out of these little issues. But I think a charging problem may have been present then and is getting worse now. Its been so long I cant recall.
    But I do know if these car don't see enough voltage throughout the circuitry, crazy things happen
    Would also explain why the car ran terrible when shut it down and started it back up last night. The starter probably drained the little bit of energy that it had and then there wasn't enough to properly energize the relays.
  23. #698
    Mar 2016
    greece
    bmw 325i 1998 coupe
    Awesome, thank you.
    after that run the idle was terrible ,i was raising the rpms in order to keep it alive,the next day it never start so i replaced the alternator ,charged the battery and everything came back to normal
  24. #699
    Virginia
    97' m52 turbo
    That is good news for me, not for you.
  25. #700
    Mar 2016
    greece
    bmw 325i 1998 coupe
    as i sorted it out i am glad that didnt happen something worse due to lean afr under boost
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
