Page 23 of 78 FirstFirst ... 1314151617181920212223242526272829303132334873 ... LastLast
Results 551 to 575 of 1931
Thread: m52 Turbo Build
  1. #551
    Virginia
    97' m52 turbo
    Quote Originally Posted by Thompson501 View Post
    Talking of bikes, I let a friend drive today.
    he spent time racing sport bikes in the past
    he said diving on boost was like being on the bike.
    his hands where shaking, he said he had no idea the car would run like this
    he said, is this shit legal?
    makes it all worth it, even the 16 hours installing exhaust mani
    Lol,
    Next time mani goes on with head off
    I'd be surprised if the car wouldn't pull on my bikes at around 14 psi
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  2. #552
    Virginia
    97' m52 turbo
    So I just took my friend for drive. His fast car is a cobra.
    He said that I shouldn't go over 7 psi and that if he raced me he would see a green line flying past him as is.
    Couldn't get over how the car felt
  3. #553
    Vancouver, B.C., Canada
    '97 M3
    I recommend that you turn up the boost a lot more.
  4. #554
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    20 or bust.
  5. #555
    Virginia
    97' m52 turbo
    The car freaking chirped 3rd gear. I'm pleased
  6. #556
    Mar 2016
    Australia
    e30 318i, 135i
    If it only chirps 3rd gear, instead of spinning the instant boost comes in, you're not running enough boost
  7. #557
    Virginia
    97' m52 turbo
    Quote Originally Posted by ba114 View Post
    You guys are crazy
  8. #558
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    20 or bust.
    Lol 20 psi raj? Come on now
    I'll do 20 psi if you build a motor for me. Ill buy the parts
  9. #559
    Virginia
    97' m52 turbo
    Diamond plate floor pans
  10. #560
    Sep 2008
    Toronto, ON
    6465 328ti
    Lol, I been running 20+psi all summer...I recently went down to 14psi to do some troubleshooting and the car felt n/a...
  11. #561
    Virginia
    97' m52 turbo
    Quote Originally Posted by e30kid89 View Post
    20psi and trouble shooting in the same sentence.
    Wonder if there's any correlation there?
    Lol
  12. #562
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by 328iFun View Post
    Lol
    There was, troubleshooting the boost controller to go up to 30psi, hehee
  13. #563
    Virginia
    97' m52 turbo
    30 psi doesn't sound like a good idea
  14. #564
    Sep 2008
    Toronto, ON
    6465 328ti
    E85 says otherwise
  15. #565
    Virginia
    97' m52 turbo
    Went ahead and got rid of that shitty glove box box
  16. #566
    Virginia
    97' m52 turbo
    E85 says otherwise
    Just make sure you stay close to a e85 station
  17. #567
    Sep 2008
    Toronto, ON
    6465 328ti
    Lol, no need. Flex fuel/an ecu that can manage it ftw. I've started 500mi road trips on e85 and finished them on pump 93. No prob bob :p
  18. #568
    Virginia
    97' m52 turbo
    Well that's good!
  19. #569
    '97 M3
    Lol, no need. Flex fuel/an ecu that can manage it ftw. I've started 500mi road trips on e85 and finished them on pump 93. No prob bob :p Sent from my iPhone using Tapatalk
    I want that.
  20. #570
    Virginia
    97' m52 turbo
    Quote Originally Posted by chikinhed View Post
    I want that.
    Sounds convenient
  21. #571
    Feb 2016
    toronto
    if you don't mind me asking where are you getting e85 in Toronto ?
  22. #572
    Virginia
    97' m52 turbo
    I have 2 e85 stations around me, both are about 30 miles away
  23. #573
    Virginia
    97' m52 turbo
    I guess with a super programmer anything is possible.
    But assuming e85, your running stock hg or thickness.
    In which, you woudlnt catch me anything over 10 psi max, regardless of how good of a tuner you have.
    #notworthit
  24. #574
    Apr 2006
    Minnesota eh?
    86 325es
    I run 32 lbs on a stock head gasket with s54 head studs. Whats the problem? Less than 20 lbs is girl boost.
  25. #575
    Sep 2008
    Toronto, ON
    6465 328ti
    Yup. My turbo is merely farting below 20psi anyway...
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
