I offered him 750
Brand new gtw 6262 or gtw6265 is close to $1k BB.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I've got an AA and that one looks quite different, odd WG port on it. It seems pricey, I got my stage 2 AA for $350 used
I went F1 stage 4 with chromoly flywheel, holds up well and good drivability.
Seems high to me. I got a GT3582R and turbo blanket for $800 off craigslist.
I saw a spa manifold, motor mount arm, and wastegate on the boosted e36 world classified facebook page today
S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
97 BMW M3 | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
Soon I will be selling a GTX3582R, Steedspeed open T4, Tial MVR and I can throw in a 3.5" down pipe with WG pipe. I made 660 whp with it. I'm not sure what it's all worth though.
Don't worry about the indentation. Fill it with JB Weld if you want.
https://www.bimmerforums.com/forum/s...road-turbo-arm
Just going to leave this here.
I just realized I may be the first person on the forums that is doing a full restoration and turbo build at the same time.
correct me if im wrong
is this a garage or your house, looks like a sick place to do some work!
Turbo Drain -
I've read that most bottom mount guys tap the oil pan above the oil plug. I'm pretty sure I don't want to pull the pan and the tap it. There have to be other options here?
I was thinking of using a scavenge pump and either tapping the oil cap or a cylinder head bolt somewhere?
Any suggestions?
I tapped my oil pan above the drain plug and I do not have smoke issues. Some have also used the drain plug as a drain for the turbo, but I don't have any experience with that.
Blow/open the drain plug out to 1/2NPT.
1996 332IS
Built 3.2
Butters,
I had read a post from awhile back about manifold vacuum routing (and connections that should not see boost I.E. PCV) by fly. He said he got some of the information from you.
After reading what I understand is that any connections that lead from the manifold then to the head or block should disconnected from the manifold and then vented atmosphere?
You mean crank case ie valve cover/oil dip stick tube. Get rid of all that cyclone separator crap.
1996 332IS
Built 3.2
Ill be the proud new owner of a Garrett GT3582R sometime this week. Hopefully Thursday.
http://www.ebay.com/itm/152445298251...%3AMEBIDX%3AIT - Got it for $950.01.
I've prob spent 3.5K so far... geez.
Will post pics on arrival
I've been doing some research on Methanol and it seems to me that a meth setup will give me even more piece of mind.
Anyone on here using one? If so who'd you go with and why?
