Page 14 of 78 FirstFirst ... 4567891011121314151617181920212223243964 ... LastLast
Results 326 to 350 of 1931
Thread: m52 Turbo Build
  1. #326
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Yup I could do the whole turbo deal even cheaper the second time cause I wouldn't by so many things two and three times trying to figure out what works and what doesnt..
  2. #327
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    Very true.
    Usually just minor things though. Glad you guys on here have been such a help with some of the more important items, for sure
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  3. #328
    Virginia
    97' m52 turbo
    Will be taking charge pipe to be welded.
    Which pipe should I use? Are the bov and maf flange too close together in the first one, or would I be okay?
  4. #329
    Apr 2006
    Minnesota eh?
    86 325es
    I would want them farther apart than the lower one. Do they both actually fit?
  5. #330
    Virginia
    97' m52 turbo
    Well, not perfectly. But mostly. There are in between
  6. #331
    Virginia
    97' m52 turbo
    Talking about the flanges? The one with them closer fits better to the ic
  7. #332
    poconos pa
    e36 m3, turbo e36
    The top one would be better, a few inches of straight section before the maf is good. Also bov to close to maf can cause idle issues depending on the bov used.
    -sold...replaced by turbo e36
  8. #333
    Feb 2012
    1995 BMW M3
    Def top one
  9. #334
    Virginia
    97' m52 turbo
    How about this
  10. #335
    Virginia
    97' m52 turbo
    Think this one might be it. Was worried about the hood closing considering the size of big in the last pic:
  11. #336
    Virginia
    97' m52 turbo
    Bov*
  12. #337
    Feb 2012
    1995 BMW M3
    Looks fine that pipe enters the boot at a weird angle and might blow off at high boost but for now I guess it'll work.
  13. #338
    Feb 2012
    1995 BMW M3
    This is mine. My bov is on the underside and a few inches down from the 90° bend.
  14. #339
    Virginia
    97' m52 turbo
    It won't stay at that angle Will enter into it straight. I couldnt hold there and take a pic at the same time neatly. Boot Will be replaced with more durable one soon.
    Is that what you are tlkaing about the angle?
  15. #340
    Manchester, N.H.
    96 332IS 6466 turbo
    Put the bov as far away as you can from the MAF. Or you will have issues like stalling when lifting off throttle. If its too close it will cause the MAF to go to 0v and shut your fuel down as it gets stuck in the eye of a tornado.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  16. #341
    Feb 2012
    1995 BMW M3
    You can see my bov in this pic. Works excellently.
    Also ignore the pic of the lambo didn't mean to ad that lol...
  17. #342
    Virginia
    97' m52 turbo
    How about this then:
  18. #343
    Virginia
    97' m52 turbo
    Lol I feel like we could do this all evening
  19. #344
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by 328iFun View Post
    That would be great but make sure the bov is easily accessible so you can work on it/remove it easily with everything installed. I think the location of mine is ideal. It's far from the maf but is easily accessible.
  20. #345
    Virginia
    97' m52 turbo
    That's true didn't think about that.
  21. #346
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    I put mine on before the intercooler
  22. #347
    Manchester, N.H.
    96 332IS 6466 turbo
    Remember the purpose of the bov, its to protect the turbo from stalling/compressor surge. So like Crazy showed, that's acceptable as well.
    1996 332IS
    Built 3.2
  23. #348
    Feb 2012
    1995 BMW M3
    It just needs to be between the compressor outlet and TB. Only issue with crazy's location is ease of access. I'd rather have mine accessible from above but it doesn't really matters.
  24. #349
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    Mine has easy accesss I can turn the wheel and get to it if I don't want to jack up the car
  25. #350
    Virginia
    97' m52 turbo
    Excuse my ignorance but what is the contraption to the right of your intake manifold. I think I may want one...
    Thanks for all the input guys,
    will probably go with the last pic I sent. Front bumper is easy enough to remove if I need to mess with it. By the time I get the car officially on the road anyway I would hope that I wouldn't need to play around with it too much anyway. Still have a ton of bodywork I need to do
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
